So this is basically everything you need or want to know.
Toyota FT86 / Scion FR-S / Subaru BZR
460mm from ground to the center of the crank/gravity (low CG)
53:47 F/R weight split
0.27 Cd (coefficient of drag)
D-4S DI engine tech (direct injection pairs with secondary EFI)
1,998cc Displacement
200 HP
151.2 ft-lbs torque
7400rpm redline
12.5:1 Compression ratio
86mm x 86mm bore/stroke
Mcpherson front suspension / Double wishbone rear
Rear seats fold (as one unit)
Cup holders can slide / be removed
Can carry 4 tires in rear
200 HP
151.2 ft-lbs torque
7400rpm redline
