FT-86 to be named FR-S...
    Originally posted by MarkMash View Post
    if you prefer the TRD style spoiler (way less gay) you could stick that over the drill holes from the previous one.....
    I've got this spoiler on mine
    Not a huge fan of how these look stock, but that looks tits.
      Originally posted by blue_s15 View Post
      Forgot to ask but hows it sound now? Every non stock one I've heard has sounded like aids. I just want the extra power, not interested in making it louder.
      It sounded ok... Wasn't heaps loud but louder than stock
        I think mine sound good. Especially with exhaust cracking and popping on overrun and upshifts. I should put up a vid for PF.
          My mate finished his AVO kit install, it started first go on the standard ROM and we didn't have any major issues after heatcycling it (just driving it round in vac).
          Now taken to tuner (Unigroup) who flashed his file and car doesn't start, struggles from off-on-off-on when cold - the tuner ended up jumping the starter motor and subsequently installed another button for it (WTF?)
          For hot idle/start, if it starts have to hold open the throttle immediately otherwise it will die.
          The only other thing is the ABS + TC lights come on, which leads me to MAF? Car is an automatic if it matters.
          I asked him to try standard factory map and see if there any change in behavior.
            Flash tune ftw...
            Originally posted by cheapracer
            Sperm are clever little fuckers that got us where we are today. You've never heard of pre-cum by the way?
            Originally posted by Nugs
            That's why I punch myself in the nuts before sex, get them disorientated.
              Jam the car up the tuners arse. Ran before but not after... wtf
                Not to mention the awesome new starter. ...
                  To be fair to tuner gmx says
                  "they flashed *his* file"
                  so looks like a tune that is supplied by avo? So all unigroup did was flash the ecu and the issues started from there.
                    I just got some stock BRZ headers and apart from the cat removal there would be fuckall difference between any aftermarket ones and the std ones. Might make some new secondaries and see if there is any gains.
                    Ferdie?
                      Were the AFRs checked?
                      My car
                      Corolla
                      I'd have no qualm about punting a kid into the fresh produce section if it meant the difference between getting a set of night vision goggles or not.
                        if you want me to fix it give me a call...
                          Ferdie?
                          Looks like that's what Toyota NZ did with their TR86 track cars: http://www.speedhunters.com/wp-conte.../TR86_5812.jpg
                            I tried to steer him your way but his already had Unigroup fiddle with it and wants them to fix it since I think he already paid them for the work.
                            Yea I haven't had a look at the car yet but he said once the car is running it is fine. They have only done 2 (or 3) MT 86s and didn't backup OEM rom from the sounds of things.
                            He did tune it, I didn't ask my mate for specifics/numbers but the gist of it is, once it's running, it's fine and was tune-able. It seems to be something to do with engaging the starter motor and/or crank enrichment.
                            They are using BRZEdit which seem to be tightlipped denying any known issues to overcome with Autos (if that is the problem).
                            I don't have any logging sw or hw for subbies, but I guess with factory WB O2 it should be piss to do.
                              Ferdie?
                              when do you want my car??
                                if it was BRZedit then they would have the oem roms to work from.. the starter will disengage when the engine rpm is over a certain point,
