Recommend me a home hoist!
    You would have to have built the slab that way to start with. Chasing a hundred mil out of even a 150 slab would leave fuckall.
    If you could remake the feet to sit up on top of the existing slab it might be ok..
      Yeah I would of told you to fuck off chasing out the floor for a hoist.
      As Muz said the only way to get it right would be to cut out the area of floor the hoist was going on then re-do that section of slab. Easy enough job to do that but still a fuck around.
      Any one know the specs that the slab needs to be to fit a 2 poster?
      I have been trolling ebay for weeks now looking for a 2 poster and want to make sure my slab will be thick enough other wise I'll drill a couple of 400mm holes in the floor and do some new footings for one.
        100mm std slab. But having said that, how many domestic slabs have been poured correctly?
          from my 10 years cutting the cunts prolly around 70% of them are right.
          I should be sweet my driveway and slab where built for a tow trucks to park on everyday as the old owners had 3 trucks.
            They always seem to have tiny little bases which seems like a mistake to me. Having said that most are bolted to commercial slabs where the thickness of slab is much more likely to be consistent/ sufficient and the concrete actually be checked for strength..
              Originally posted by choppo View Post
              Whats the hotness on 4 posters? Need to be able to open the car doors.
              For me, I couldn't fit a 4 poster in
              My garage has a centre pillar, and you have to drive straight onto a 4 poster.
              I drive in and have to hook it slightly, the hoist is positioned slightly off centre and at an angle to make this easy.
              Height/Width
              measure your car from sill to roof and measure your height add 300mm and there you go.
              posts height is about 2770mm
              total lift height to top of pads is1900mm + car height
              overal width is 3250mm
              slab
              As choppo said, if its a fairly modern slab with reo, 100mm, otherwise 150mm
              Installed cost
              I already had 3 phase in the electrical box to drive the airconditioning system. But all the neutrals had been used up, so needed a sparky to put a new panel in.
              I bought a 100 metre roll of 2.5mm 4 Core + Earth Orange Circular 3 phase cable, a 25 metre roll of 20mm flexible conduit, a box of half saddles, and ran the electricity myself to cut down on labour.
              Then had the sparky put in a switch in the garage, and connect up to the hoist.
              For the power side of things, I spent $320 on cable stuff and $400 parts and labour with the sparky. ouch.
              Hoist itself was second hand, and from a workshop around the corner from my house. The hoist guy is my mate, so I paid sweet f-all for the hoist and installation, however allow $2500-$3500 for a quality, work cover certified, australian made hoist second hand (installed in Sydney)
              Recommendation for installer
              Richard Brown from Citiwide Hoist Service. Phone 0402272944
              Based in Camden, covers all of Sydney. Great, honest guy.
                Originally posted by seedyrom View Post
                This is the best 'concealed hoist' i've ever seen
                  www.superhoistplus.com.au
                  Good guys. Good hoists. Run by an old fitter and turner
                  www.qmap.pub
                  THE BET IS YET TO COME:
                  https://youtu.be/jabC1joa9ts
                    My ravaglioli required a 150mm slab (so did the molnars I was looking at with SL81 mesh), over a minimum area of 4m wide by 1.5m deep.
                    Gees you really didn't muck around with time. Well done, you will wonder how you got by without it.
                    GAS 260Z RB26DET
                    GAS 1600 3SGE BEAMS
                      is it a Bad Thing to have suspension hanging like that for extended periods of time?
                      2011 Smart ForTwo
                        Originally posted by Glenno View Post
                        Could you chase out the concrete and recess a non clearfloor hoist into the floor so its effectively a clearfloor model without the overhead cable tray?
                        Not on the majority ive seen. You have to lower the arms to the bottom of their travel before the safety locks will disengage and you can now move them freely. Soon as you lift it up, they lock solid in position. If you recess it into the floor you arent going to get the arms all the way down, so I think it will be a problem. Likewise, you'll have to make sure the slab is strong (thick enough) too, so it sounds like a fuckload of work for something.
                          Dino, I've had two of those hoists in my workshop for 2.5 years and not had a problem. They are good units and very well priced. Sensibly priced unlike Molnars.
                            depending on how often you use the thing having the bump on the floor is a major pain in the arse. like mentioned it gets in the way of gearbox jacks, oil containers etc. not to mention if you are looking up at the car working you can trip on it. i havent priced hoists for years but if you have the roof clearance and can strectch for one with the cables going over head rather than on the floor, do it.
                              http://www.maxjaxusa.com/ Somethign like this is worth a look when you have low clearance. Doesn't lift the car that high though but is also handy if you have a small space and need the hoist out of the way when not in use.
                              Any idea if these are available locally?
                                yeah it can degrade rubber bushes, but a few days aren't a problem, or if it has neoprene bushes everywhere.
