Originally posted by tut
View Post
Torque dry Vs lubed chart
Originally posted by tim510More rabbit less turtle!
http://www.Tutter.net
screw you thenOriginally posted by tim510More rabbit less turtle!
Just dont take any chances, i just moly lube the fuck out of everything, threads, washers, nuts whatever
2JZ KE20 Corolla 7.97 @ 178
SR20DET Gemini 8.70 @ 157
http://www.oke020.com
7.xx is no longer a challenge
(sort of)
Good old cadmium plating is an assembly lubricant and found all the way up to quite high end aerospace fasteners.Originally posted by fantapants View Postslight offtopic, forgive me or yell at me either way
i come from an industry where the mantra is grease the fuck out of it. if it metal on metal, grease it. If it has a thread grease it. If it needs locktite, grease it and locktite it. I realise alot of this is just passed down incorrectness, but for me when im working on engines and the like, im curious why i havnt seen ANY grease on bolt. So when stripping my 3sge of ancilliaries like ac, pwrstearing, etc all the bolts are dry.
I know there has to be a real smart reason for this, i just dont know what it is, any one know?
FWIW for the bolts i replaced that i felt needed it i lubed the base of the head, and locktite on the threads....Claimed horsepower sceptic.
Well lets take a stud for example. Fit nut and setup a dial gauge on end of stud, apply torque X with no oil, measure stud extension.
Then back off, lube everything or what ever you wish to test using the lube you want to test, then set up rig once more. Apply same torque and measure new extension on stud.
Given the stud has a fixed tensile strength after the first torque setup, the experiment should prove what you want to whom ever.
Or just calculate it.
Interesting, not many people think in the terms of clamping force which is what you are trying to achieve by applying a given torque."What mans mind conceives, mans character creates"
www . ozhunting . com
http://www.futek.com/boltcalc.aspx?mode=metric
Gives you a max torque reccomendation plus a nominal value. Not that helpful on its own, but it does list the tension in the bolt at these torque values on the results page. You can use this to show what impact friction has.
The K factor lets you play with friction due to lube.
This subject is one that I really like talking about but can easily go beyond the scope of this forum.
One of the biggest causes of gasket failure is due to inadequate clamping force by lack of tension created from excess friction due to lack of lubrication.2017 Ford Ranger XLT (Jeep Wrangler recovery vehicle)
I always thought the main cause was listening to a rap song (bad tune) :w:Originally posted by xw351 View PostThis subject is one that I really like talking about but can easily go beyond the scope of this forum.
One of the biggest causes of gasket failure is due to inadequate clamping force by lack of tension created from excess friction due to lack of lubrication.E36 M3 12.92 @ 108.64mph, N/A 3.0L
50cents says it trueOriginally posted by morerevsm3 View PostI always thought the main cause was listening to a rap song (bad tune) :w:2017 Ford Ranger XLT (Jeep Wrangler recovery vehicle)
