Originally posted by HoonBoy
View Post
Aldi special - air compressor
Ive got one of these and a large one...this one is handy for pumpin up tyres/spinning off a few wheel nuts etc....ar as Cammo said,air ratchet work...I tossed the curly hose in the bin Day 1,and now use a long air line to keep the noisy bastard around the side of the shed...I have painted small items with it too,but even on low pressure it runs out of puff pretty fast..
If you just want something convenient to use every now and then I say grab one! Years warranty will just about see you through
This will have to do with the rattle not the compressor.Would it be able to undo say a crankshaft nut?10.83 @ 125
Originally posted by crackaSome conclusions empirically were that a large protruding ridge like a prolapsed arsehole around the runner was largely beneficial.
nope. sometimes it's worth your sanity not to skimp. tools is one of those times.Pest Control - Brisbane, Gold Coast, Ipswich and South West QLD PF discounts apply.
It'll work just fine for general use. I have a GMC that's identical to that compressor, it's now five years old. I have two actually, I gang them together to paint cars. Despite my never having drained water out of them or checked oil, they keep going. One WILL run a rattle gun, I do it nearly every weekend.
At $99 or so to replace them, I give no fark if I ever have to replace one (and as I said, I haven't had to, bloody things!).Life's too short to drive boring cars.
tez, if you want a compressor that can handle a rattle gun at full pressure for 10+ seconds, you wont be looking at a low end one.. unless you join 2-3 of them and bypass the reg.Originally posted by Rdyno70ynu has to be the most retarded cunt here. "Help me please" me "you need to remove your head" him "fuck off cunt I'm to lazy fuck off out of my thread you told me to do something I don't want to do so you're a cunt fuck off can some one please tell me an easier way???"Originally posted by TripperIts a tight battle between you and rogercordia for the most retarded member on here, thou i think you have it by 5 window licks
and if you want to remove your crank bolt, get a breaker bar (and a piece of pipe that goes over it so you can extend it if need be)
rest it on the chassis rail (taking note of which way the crank spins) and flick the starter over. works nearly every time
Yeah thats the method I will be using instead of buying a u-beaut compressorOriginally posted by MRMOPARMAN View Postand if you want to remove your crank bolt, get a breaker bar (and a piece of pipe that goes over it so you can extend it if need be)
I bought a similar looking one from Aldi a while back and it wouldn't do shit so I took it back and got a refund. It would spin the socket no worries in free air with no load but as soon as you put it on a wheel nut it wouldn't do anything.Originally posted by CussCuss View Post12v is even better! (assuming you are mostly using it around your car)
http://www.4wdworld.com.au/Handy-12v-Impact-Wrench.html
Have one of these and its great for wheel nuts.
I got one from Dick Smith a while back, worked okay for a few uses, but now doesn't seem to 'engage'. Thinking back the battery I was using may have been down on voltage, so may be related.Originally posted by Falchoon View PostI bought a similar looking one from Aldi a while back and it wouldn't do shit so I took it back and got a refund. It would spin the socket no worries in free air with no load but as soon as you put it on a wheel nut it wouldn't do anything.
I did manage to get it to undo an alternator nut that I couldn't get manually though.
Was $20 or something DSE
FWIW I used a cheap shit one to paint a car a while back. What I did was get one of those huge natural gas bottles and connect it to the compressor (after welding in a drain fitting on the bottom. So the little compressor take years to fill it up but you have a bigger reserve, works alright. Can get pics if anyone is interested.
