Using a front mount intercooler as a RADIATOR ?
Itll work and probably quite well. While water is obviously a lot denser than air and intercoolers are full of fins, they are much thicker than radiators so will probably work out the same flow rate or better. Easy to test off the car.
the problems you will encounter are blockages due to the internal fins and possibly corrosion of the fins.Turns out, far too much has been written about great men and not nearly enough about morons
DpTurns out, far too much has been written about great men and not nearly enough about morons
for what it's worth i would have said the sameOriginally posted by Jim View Postthe problems you will encounter are blockages due to the internal fins and possibly corrosion of the fins.
also
the internal volume of the intercooler filled with liquid could be quite heavy if it is going on a lightweight race car
the velocities in a single pass arrangement might be low enough that the solids (e.g. broken off scaling) could settle and block some of the passages
custom end tanks would be required = extra material costs & fab hours
Dont you have to run the water bottom to top in a radiator? If so, that means youd have to turn the core sideways which will make it massively high and likely not fit so well. Either that or cut it down which doesnt make much sense.
I reckon sell the expensive cooler and buy a good quality radiator. Sure the cooler might work but it definitely wont work better than the same $ worth of professionally designed radiator.#WHOTW award winner #blessed #susanalbumparty
It works fine. Just do it. What do you think PWR cores are when you buy them. Air, oil and water are all the same cores. I still have a 68mm PWR core as a radiator and it's 10 years old and cools great in the racecar.
Always makes me laugh the haters that have never tried something and just bag it straight away. Some people on here need to go experience things more before bashing the keyboard.
In the interest of souding professional and like Carrol Smith, we should call them 'heat exchangers'2017 Ford Ranger XLT (Jeep Wrangler recovery vehicle)
Originally posted by 02PRUV View PostWhat do you think PWR cores are when you buy them. Air, oil and water are all the same cores.
drugs you on ?
That's a sensible comment.Originally posted by xw351 View PostIn the interest of souding professional and like Carrol Smith, we should call them 'heat exchangers'
You should just shut up.
Yeah cause engineers for every car manufacturer in the world obviously know less than you and have no idea about the thermodynamics or flow properties of stuff they stick in production cars.Originally posted by 02PRUV View Post
You want a radiator, buy a radiator. Its not a 1912 Austin Humpty Supercharged Quadrofoil he is sticking a HKS ricer part in (I assume anyway) so go buy the one that fits and spend the savings on coke and hookers.Originally posted by Dimi80mm of penetration isn't bad, i wish i had that much.Originally posted by schnitzelburgerMy entire working career pretty much consists of suckin dick and takin names.
