Yeah well a 2JZ is designed to run on 100ron and 10psi but I ran 25 psi with 98 and it didn't ping with a stock ECU. So I think that its bullshit that this pings on stock boost and stock power on the same fuel with just 0.5 more CR. I am sure the auto does make the pinging worse as the engine is always loaded up exactly at the point where it pings the most, around 2500rpm. On gear changes your foot stays on the throttle which means boost spikes as the RPMs drop. That means pinging on gear changes. I think these factors make the autos ping more than a manual. In any case hot air and heat soak in the top mount intercooler have to be adding to the prob. Prob is that a better flowing cooler might also increase boost in addition to cooling the air which will be one step forward and one step back in terms of detonation. Going for a tune is always an expensive option and last resort IMO unless the stock ECU and be tuned.
Is there a way to check error codes on this? Sure it might be this dead sensor or that dead sensor, but without having known working spares its a bit hard to test?
The Caldina is a ST246, the engine has unpainted rocker covers. So its not a black top. I read somewhere that they had a black top. So I was wrong there. So can I adjust the base timing on this version?
Lets end any speculation about how good/bad the topmount is. I just installed my multimeter with temp probe before the TB. Now I look like a ricer with a big yellow "gauge" jammed under my wiper. Ambient temp is 28, yet the probe says 35 and I haven't even started the engine for 7 hours. Will report back after the drive home, but I don't expect much traffic on this trip.
