Originally posted by Tripper Johnson
View Post
HID light kits
What I have done with two of my cars rather than go the HID root is use an upgraded plug and play wiring loom and also 130/90w Hella Globes. These give excellent light output. My 4x4 with crystal semi sealed housings and this conversion easily outshines my charade which has a HID kit. Only downside is cost as you are looking at nearly $200 for the loom and bulbs.
Bottom left for the loom to suit H4
http://brightlightautoparts.com/Headlights.html
Thanks for the link, Im surprised how cheap some of their stuff is!Originally posted by Tripper Johnson View Postunless the car has projectors i wouldnt even go there, you can get retrofit kits to put proper reflectors that suit hid bulbs into standard headlights http://www.theretrofitsource.com/#WHOTW award winner #blessed #susanalbumparty
I'm running the same projectors in a BF XR6T - easy as to install - not the best projector on the site but installation makes up for that...Originally posted by Kyle View PostThat's correct.
Forester has h4 globes, grabbed the morimoto mini d2s projectors and they slotted straight in. Couldn't be easier
they'll be releaseing a new version of the Mini D2S early this year apparently so I'd probably hold out til then
so given the fact that most cars have plastic reflectors and a plastic lens these days, how do you over come the extra heat the bulbs put out melting and or damaging the housing and reflector and the lens ?Originally posted by EnFlaMEd View PostWhat I have done with two of my cars rather than go the HID root is use an upgraded plug and play wiring loom and also 130/90w Hella Globes. These give excellent light output. My 4x4 with crystal semi sealed housings and this conversion easily outshines my charade which has a HID kit. Only downside is cost as you are looking at nearly $200 for the loom and bulbs.
http://brightlightautoparts.com/Headlights.htmlyou cant spell advertisements without semen between the tits
What ballasts did you opt for? I went for the 55s..Originally posted by Mitch_ View PostI'm running the same projectors in a BF XR6T - easy as to install - not the best projector on the site but installation makes up for that...
Fuck you'd have room in a bf headlight for two each side! Love it
