Thief Proofing a Trailer.
    Leave it on blocks?
      be able to afford a house with a backyard and a gate?
        1. Sleep in it with a loaded shotgun by your side.
        2. Insure it for three times what it's worth.
        3. Buy a shed to lock it in with insurance payout.
        The World's Best Pest Control in Brisbane, at PF mates rates, PM me.
        when all else fails, hit it harder.
          leave your Datsun on it
            I use the cage style one. Padlock can't be accessed with bolt cutters. My trailer sits in the front yard all year round but doesn't look to appealing anyway.
            Projects:
            '90 2jz-gte 929
              Originally posted by Southo View Post
              All you are doing is slowing them down or making them move onto the next one..
              If they REALLY want it, they will take it..
              A towball / Hitch lock will stop them from towing it away, but not stopping them dragging onto a another trailer / tilt tray or just dragging it away from chaining it to another towbar etc..
              A wheel lock with stop them dragging it away any great distance by another vehicle, but it can be dragged onto a tilt tray easy enough.
              A Cable lock changed to something fixed will stop them physically taking it (until they cut the chain / cable)
              .. when leaving mine in dodgy areas overnight, I just had a internal towball lock, (stopped it being attached to another towball)
              then padlocked the saftey chain around the drawbar and jockey wheel (so it couldn't be raised) so it couldn't be used to drag it away...
              and finally, had a chain and padlock through the side rail / gates / rear rail around something solid..
              I too use this device plus wrapping the chan around jockey wheel . I guess it works as I still have the trailer. I also padlock the safety chain to the 4b as well as the D shackle.
                Originally posted by GreatWallGT500 View Post
                Arthur, on my car trailer i use one of those ^^^^^
                It needs to be locked all the way in or "home" to be effective though.
                Added deterent I use a padlock on the hitch lock.
                AND, if leaving it in a shitty spot, I take a really strong Kryptonite cable lock (cble is maybe 5/8" thick, without the coating) and run it through wheels/chassis, around a fuckin tree or post/fence/other vehicle, just to make it a real cunt.
                I figure if you make your harder than the next poor cunt's, you at least stand a chance.
                  paint it army camo so people wont be able to see it
                    With portable grinders so cheap these days nothing is safe.
                    Maverick - gone
                    Turbo AU Ute
                      put a sign on it saying "FREE TRAILER" then everyone will assume its shit and not take it
                        Another vote for the last one in GreatWall's pics. Can be used when the trailer is on the car as well. Cheap and probably as good as anything else.
                        Won't stop someone with a spanner and spare hitch to bolt on.
                        You can only make other trailers look more inviting to steal. I achieved this by leaving mine in the open for the last 6 years and letting it rust :O
                          :O
                          id just weld the nuts to the bolts
                            McHitch
                            3D scanning
                            3D modelling
                            Structural certification
                            3 and 5 axis milling
                              When someone tried to steal mine when it was parked in the street a few years ago they didn't even try to hook it up to the towball, just put a chain between towbar and a frame. Problem was shitty rusty landcruiser towbar was not as strong as the 17mm cable round the tree which they either didn't see or figured would break as they drove away.
                              Came out in the morning to find trailer a metre further down the street than normal, landcruiser towbar and bolts etc on the ground in front of it, and the cable now has a permanent kink in it where it pulled tight against the rails of the trailer.
                              In short, they didn't get it, lost a towbar and chains. Police said, if you are going to leave it in the open, keep a car on it, they don't want to be hauling a two ton plus thing around, they want the trailer, not the shit on it. So now it sits with a car on it most of the time with the same cable round the same tree.
                              Radical SR3
                              HSV R8
                              BMW 325ti Proddy Car
                                Do what I do, anticipate the cunts are gunna knock off the one down the street before mine it's easier than pulling mine out of a steep driveway.
                                What's one of those tow ball lock things worth?
                                - PSN: rotacoupe
