Hydro'd my engine/Ford are awesome.
    Originally posted by choppo View Post
    Rolls up to dealer and say "look, my air filter is dry!!!"
    (After 3 days in front of a heater)
    this.
    if there was water ingress, you would know where it came from.
    even if the water was only a few hundred mm high, whats the bet you hit it at speed, and splashed water everywhere under the engine bay?
    failed jewish stocktake attempt imo. otherwise you would have documented everything and pushed ford a lot harder (threatening lawsuits and such)
      Fuck cunts stop fucking arguing, we all get it muz and fondles want to furiously fuck in a paddock full of daisy's but keep your shit fight out of every ones view.
        ^ This
          It's hard to describe how much I don't give a fuck about this peanut and his bullshit.
          Don't assume that me posting means I am somehow invested in this degenerate.
            Maybe you should show how much you don't care by not posting in his threads from now on?
              Popcorn.
              Originally posted by Gussy
              It's the PF way. "Put a twin turbo LS in it brah, you'll have it converted and running in 2.5 hours and make an eazy 1000rwkw, lulz" All while the same people who suggest this stuff drive around in a corolla and have a fucked VN sitting in the garage for the past 3 years as a "project car."
                facepalm
                  Originally posted by MRGREATWALLMAN View Post
                  this.
                  This^
                  No such thing as mysterious water intake that is enough to bend a rod or two.
                  Something is missing in this story.
                    Originally posted by Mr Ed View Post
                    I was in BKK last week. I saw more mercs and porches there than I see here. I saw a massive RUF tuning billboard, which amazed me, its something I bet 99% of aussies have never heard of. Seems to be alot of money there, just perhaps not as evenly spread as the dumb masses would demand here.
                    I'm convinced the general Australian "wisdom" is backwards, way nicer cars, nicer public transport, better roads, cheaper speeding fines, better hospitals, etc etc.
                      This^
                      Yes, you are correct good Sir..
                        Originally posted by Don Mega View Post
                        Anywho coming home one evening turned into my flooded street bout 10m behind a Toyota Yaris and all going swimmingly well bout 500m in the car give's a stutter and looses power so I give it some more throttle and it stalls.
                        Hmmmm
                        Hit the key and it cranks a bit then nothing, all the lights go out...... rut roh.
                        Give it another crank same deal.
                        So fuck-it, leave it there in the middle of the road to go grab some beers from the 7/11 and decide what to do.
                        Rescue guys shows up and give me a jump start and she fires up, rattling like a mother fucker but running none the less so I drive it home.
                        Random brain fart - Could the losing power/stall thing be water in the electrics, then somehow water going back up the exhaust into the engine? I can't see how but if the air cleaner was dry there's only one other hole the water can get into the engine through.
                          dodgy thai mechanic cunts don't spring to mind? perhaps a bitter ex ladyboifriend that was dirty sanchez'd?
                            fondles is right though. fords are awesome.
                            i think this is a more appropriate thread for this..
                              I gather your not wanting that hug then ?
                              Every part of the engine was examined and evey part if the inlet tract pressure tested for leaks..... nothing.
                              Only water to be found was some moisture in the EGR valve.
                              The engine guru's actually had a theory that somehow the crank sensor was knocked out of whack and caused it to inject fuel at the wrong time which could have caused it to lock. no way to substantiate this theory as the engine and all parts attached to it were completely dis-assembled by the lovely Ford dealership.
                                That sounds more possible, though the injectors would have to stay open for a fair while to fill the pots with fuel.
                                It would also make for a warranty claim.
