Car Detailing
    Any tips on how to detail the engine bay? Doesn't have to be show car quality, just want to remove the film of fine dust on everything.
      SO I have some rims to tidy up.
      Autosol was suggested. Can you use it with an electric polisher?
Name:	219087429_530373294866874_9222809379711508511_n.jpg?_nc_cat=106&ccb=1-3&_nc_sid=ae9488&_nc_ohc=Yi5jCN23Gb0AX-w5CmC&_nc_ht=scontent-syd2-1.xx&oh=dfb25075eb030f8eae98233a00f382d0&oe=6122A51C.jpg
      Dr Hoon
Name:	221354848_519875305944968_6767345018071719753_n.jpg?_nc_cat=111&ccb=1-3&_nc_sid=ae9488&_nc_ohc=kAVAD3j1NnMAX9QLZLf&_nc_oc=AQnC5Dfv_6hl_Sp4ZwJAbhVUWYZNJ6jVOuXJ90sAtbbSl2rM0--fkw-e0Z5_tnyIrlY&_nc_ht=scontent-syd2-1.xx&oh=cbdaea22b792
        Dr Hoon
          I did the engine bay of a friends (nopics) Mazda Demio this afternoon.
          It was like yours...completely covered in a fine dust, so rather than involve excessive amounts of water by using a pressure washer. I just got a nice soft clean 1" wide paint brush, and gave everything a brush off, and to loosen anything stubborn from in the crevasses and corners etc.
          Then I used an old rag to wipe down anything with an oily residue first, before using clean cloths and spray detailer and giving everything a good once over.
          Depends how fussy you want to get, but I spent about an hour on it and it looks like new now
            So other than the spray detailer, clean brush and rags, NO product as such?
            Jim.
            VS ute appreciation society
            (you know it makes sense..)
              Its a case by case basis really
              If its an old oily car from decades ago, then you will surely need some degreaser and a bit of elbow grease, but for newer cars, they typically just get dusty, so arent too tough to bring back to new.
              I have a dash and trim restorer that i use for for any under bonnet plastics, airbox, hoses, weatherstrips, and the windscreen wiper cowl etc, just to give it that factory fresh appearance
                Mr Sven. That’s the clear coat on those wheels over the machines finish failing. They are - for the purposes of a detailing discussion - done
                If you start using either acid, non-acid, caustic, jizz or spit on them it will work into those little wormy areas and start making them worse, if it’s real bad they’ll corrode the alloy rather than just discolouring it.
                  If you snow-foam you can do it with a drier mix (thicker foam) and just hose off without being a dumb idiot when it comes to putting water pressure into electrical connectors. Also stick some rags in the valley above the coils (assuming two cam) before you start as you don’t want water in the plug wells.
                  Aggitate with a softish brush if you’re inclined.
                  Then cloths and plastic/vinyl/rubber spray to do the hoses and plastics. One thing I used to do was wet soak everything in the vinyl spray. Leave it for a few hours. Then go back and mist and wipe up excess and even out coverage.
                  You’ll also find that some tyre shines/cleaners that contain cleaning agents rather than just silicone, will work great on hoses and stuff. A squirt and brushing/rubbing like you do on the tyres.
                  Once you’re at a clean point use a spray sealant on all the painted surfaces and it’ll stay cleaner longer.
                  The moment you’re done fire it up and get it warm for a bit. You can always touch up the products, but it’s best to get moisture evaporating out of the harnesses and nooks and crannies sooner rather than later.
                    Cheers.
                    So full resto, or I've done my dosh?
                    Dr Hoon
                      Originally posted by nastysven View Post
                      Cheers.
                      Resto. Depending on the finish you want it’s just a strip, a quick machine or polish of the spokes, and the repainting.
                      Functionally they’re fine now, but it’s like anything, once there’s a path under the paint/clear that genie is not going back into the bottle.
                      if you get an agent under the clear that eats aluminium then it’s going to party down hard!
                        cheers man. I'll live with the 'far from good, but good from afar' untill next year when i do the interior re trim. (year to year budget on the re-furb). i'I cant spend my holidays on travel, so I'll spend it on this shit heap.
                        Dr Hoon
