Pretty sure any device or object that obscures the plates for any amount of time is illegal to be used on roads?
nophoto
Lobster was looking at this before, And i think trying flood or block the plate with IR light would do the trick, just have a easy to reach but hidden switch to turn it on and off as needed, try your camera and the remote for the tv and you will get the idea. As for the switch something like a factory fitted switch for fog lights would work with a separate switch for the fog lights if fittedyou cant spell advertisements without semen between the tits
Problem is in SA cops will take your car from you if you run no plates. Nearly happened to me. I was just lucky as I was caught when the court case opposing the laws was going on and they weren't allowed to seize cars. Still got over $1K in fines though. Hence looking into other things.¯\_(ツ)_/¯
I'm with Tripper. Flood the shit out of the plate area with IR. No one will know except the deadshits at Govco flicking through the pics and handing out the tickets. Been thinking of doing this for 10 years but its just easier to slow down for the generally fairly well marked cameras. Unmarked cars on the other hand.......way to detect that its filth rather than gramps in the Camry would be good...?? Anybody?
AH
like this?Originally posted by Tripper View PostLobster was looking at this before, And i think trying flood or block the plate with IR light would do the trick, just have a easy to reach but hidden switch to turn it on and off as needed, try your camera and the remote for the tv and you will get the idea. As for the switch something like a factory fitted switch for fog lights would work with a separate switch for the fog lights if fitted
http://www.sunflexzone.com/product/s...countermeasureGet your hands off my penis!
Given they are moving to and using a IR flash in theory it would work, you could leave it on all the time with a switch to turn it off for those times when you have a cop car behind you etc, perhaps even mount one on the front for the cameras that get you head on. I wouldn't be doing any high speed runs to find out if it worksOriginally posted by TurbostyleR View Postyou cant spell advertisements without semen between the tits
Hmmmm .... pretty cheap as well.
Originally posted by mr.beaker View PostSomeone design a IR flood for the plate and I will do testing. I pick up enough tickets when I drive to make it worthwhile for me to do trials.
Jaycar sell IR LED's and a small spotlight type as well, maybe give those a try?
http://www.jaycar.com.au/productView.asp?ID=ZD1945
http://www.jaycar.com.au/productView.asp?ID=KG9068
First one is too big. Can the human eye see that these are on at night?Originally posted by Billzilla View Post¯\_(ツ)_/¯
