the car was wired up and running in the first 2-3 weeks , they did call as they had run into some dramas .the car was backing every 5th start or so . so i said check the cam sensor as i may not have put it in right , he then called back and said the crank bolt wasnt tight , and they would have to remove radiator to fix it i said thats fine . so at this stage the car was wired up new motor run in, so once these things were done , it only needed oil dropped fuel filters and tune .
they called the wed before i was first suppose to get it and said they couldnt find a fuel filter for the surge tank . not sure how its a 1/2- 1/2 barb barb filter . i told them if they couldnt find one leave it on there or run a piece of hose and i'll fix it , and that was the last time they called me .
