What's the hotness in oils these days?
    Originally posted by ga70tt View Post
    put penrite 10tenths into a few recently... seems to be doing a good enough job
    This is my choice. Been stocked at most Supercheap stores is a big draw, makes it easy to get in a pinch.
      (not really)
        Fuck Lonx. So much anger when you put up a thread which can never reach a consensus.
        None of us are qualified. Is one brand of oil (excluding Bill's post) guaranteed to rip your engine to shreds? No.
        I use Castrol 10w/60 as it was recommended as a cheaper alternative to his own product by the owner of Mainlube.
        A mate reckons his mechanic said never use Castrol as it is shit.
        You might as well ask "which car is best?"
          Mechanics avoid Castrol cause it tends to sludge up sooner/more frequently than others. I use whatever I'm stocking at the time. Gulf western, Penrite, whatever.
            Agreed.
            It's all very subjective.
            While some people will say their car "loves" one brand of oil, or runs "better", or "smoother", or "makes more power", or "feels more responsive", it's mostly in the mind.
            Pick which type of oil you need (Synth, Semi-synth, mineral), work out your vicousity, and go from there. Price is more important than brand.
            Originally posted by brewdles
              Probably because they're using $14/5L 20W50 in modern engines. Old habits die hard.
              Yet to see any sludging issues from using their 5W30 504/507 VW oil, and I've been using it for around 6 years.
                Proper engine clearences and tune are the answer. For race cars proper temp management with previous points is the answer.
                  I use Fuchs, it seems to be alright.
                    I should have worded the thread "which oil is best" then... but no, I was just after opinions really mate. Calm down, relax, have a beer.
                    PF Gamers List
                      Millers Nano Drive 10W40 or 10W50 depending on season and if I can get it. Engine always seems to run best on this..
                      If not, Amsoil Dominator 15W50 or RP XPR 10W40
                        Originally posted by nelsonian101 View Post
                        I've used Royal Purple Synthetic 10W 40 in a highly tuned daily driven FgXR6T circuit car for 8 years.
                        Zero problems.
                        Car has now done 226,000kms and 30+ circuit days.
                        Seriously I think that's nothing to do with the oil there, it's typical falcon tough!!
                        It's magnetic that sludges up the engine. I find edge to be the standout. I find penrite very over rated.
                          And yet 100k kms I've put on my ls1 (@225k km now) running magnatec and when I had the heads and sump off it was all very clean.
                          I don't see how any of this discussion is useful without proper test results from oil analysis.
                            ULX110
                            End thread.
                              ULX110
                              End thread.
                              Never heard of it. How much in 5l and where from ?
                                http://www.ulx110.com/index.html
                                Nothing comes close, all the race engines I build use it - strip, circuit, burnout etc etc
                                The stuff is magic & not even that expensive.
