and so it begins
    If you are still in Melbs i have a spare Hilux radiator that shoudl fit (jerry rigged), and stuff to work on it if that helps.
      Looks like blocked radiator.
        I'll see in the morning - it may have wrecked the head gasket.
        Not sure if I have the fortitude for a head gasket change in the back streets of st kilda (staying with a mate), but will re group in the morning.
        Live by the sword, die by the sword!
        Edit - if I wimp out, any recommended melb to adelaide car transport mobs? Can't be ceva or anyone big as it has its quirks obviously.
        Suggestions?
          Originally posted by Pol Pot View Post
          20 past 6 at the airport .. you hardcore animal!
          Hmmm 20 past six is all the jettards and vircunt sloths flying.
            Suggestions?
            If you need somewhere better im not on the back streets of St Kilda, but not far away (Prahran), and have an area out the back of the block that would work.
              Do u want me to call the mob my friend uses that brings crashed cars from pickles melb to Adelaide?
              Sent from my Nexus 4 using Tapatalk
              3D scanning
              3D modelling
              Structural certification
              3 and 5 axis milling
                i have a garage and tools (No torque wrench though) that you could use in St Kilda if you want mate.
                Im not only sure Im HIV positive.
                  PF-717 has full-ferserious tow hitch & also brake-proportioner/controller. Was used commercially for towing fucking heavy portable cool-rooms ...
                    This is awesome. Makes me want to do another gumtree roadtrip like I did a couple of years ago flying from QLD to Melbourne to drive back a $1200 1976 Mazda B1800 ute via the snowies.
                      not looking good, just spat all oil.
                      nooooooooo
                      Originally posted by Russell View Post
                      Where?
                      Sent from my C6603 using Tapatalk
                      Originally posted by 80DGY View Post
                      on the ground?
                      Originally posted by gat5rodeo View Post
                      Buy a 20 litre drum of oil and a hand pump. Hillbilly dry sump system
                      I laughed way more than i should've.
                      Originally posted by zammo
                      I'm the retard with the cockroach in my ear.
                        Probably stuffed the head gasket.
                        Pull the head bolts down another 1/2 a turn & jam a bottle of chemiweld in it.
                        Take it easy & it should make it.
                          ^^^^ this guy knows
                            OT: For those guys driving these cars interstate after purchase, I assume you have organized a temp driving permit from the state state authority? Anyone care to cliffnote the process? I will more than likely be doing this (buy in Sydney, drive to Melb).
                              For NSW -> Victoria you need a NSW UVP.
                              From VicRoads:
                              You can drive interstate with an Unregistered Vehicle Permit if this condition is specified on your permit.
                              You do not need a permit from VicRoads if your journey starts interstate and finishes in Victoria. Check with your local vehicle registration authority if you need an interstate permit before you drive.
                                Champ! Thanks for that.
                                According to here, one of the items I need is a
                                A safety check report or a Customer Declaration of Roadworthiness for specific vehicles.
                                Anyone know what the difference is?
