Fuck yeah, that'll be a weapon.
Compliance data, the 6 cyl cars for 1988 on were under a different compliance number. The 4 cyl car weights are much lower. In fact from memory none of the 4 bangers clear the magic 1100kg mark.
Given what I have seen over the years, most wouldn't let that stop them but it is the legit answer to the question.
From the Gingerbeers i have talked to, it doesnt matter. Its the heaviest weight for the chassis in that era.Chris
yep, triumph 2000 uses a different compliance number to a 2500, yet either can and has been engineered for a ls swap - both weigh similar, yet the 2000 should fall below the allowable. it goes on heaviest model.
same with volvo 240's, early 244 2 door cars are around 1030kg, late sedans are 1300kg.I'M NOT A HOOKER BUT 20 BUCKS IS 20 BUCKS...
Originally posted by takai View PostFrom the Gingerbeers i have talked to, it doesnt matter. Its the heaviest weight for the chassis in that era.
It is based on the heaviest tare weight for a sedan without optional extras. The RMS RVDS has all the compliance data so the info is readily accessible.Last edited by CA18escort; 10-11-20, 11:31 AM.
Originally posted by Sloth View Postyep, triumph 2000 uses a different compliance number to a 2500, yet either can and has been engineered for a ls swap - both weigh similar, yet the 2000 should fall below the allowable. it goes on heaviest model.
Also listed tare weight for 1975 244 2 door is 1220kg Heaviest sedan was the 1984 on 244GLEA 4 door at 1310kg due to all the electrics. The GLA for the same year was 1260kg so fuck all in it.
Originally posted by gtrboyy View PostIf you can find heavier weight published for a car can you use that against RMS if they have a lower weight?
Terry Bebbington who wrote Holden books '45 Years of Holdens' or one of his other publications I think had lc xu1 as heaviest torana...some dudes in Vic used there torries passed for 5.3/327.
If I can find the book & it has where technocal information came from is that enough to use the highest weight published?
If can't go 5.3 does 304ci scrape in?an easy fix is get a mate to drive in front of you at 60 then 80 then 100 and mark in on your speedo with some liquid paper.
Originally posted by TT View PostI thought they mentioned it to be a 1989 320i which was a 6 right?
I am pretty sure..... because every driver experiences the destructive potential of the effortless surge of power available through the smallest of body movements.
Dr Hoon.
Originally posted by gtrboyy View PostTerry Bebbington who wrote Holden books '45 Years of Holdens' or one of his other publications I think had lc xu1 as heaviest torana...some dudes in Vic used there torries passed for 5.3/327.
1099kg = 3000cc turbo or 4396cc NA
1100kg = 3300cc turbo or 5500cc NA
Because it isn't a sliding scale there is a a step jump at 1100kg. This is biggest issue because the LJ XU-1 was listed as 1099.6 kg kerb weight on the paperwork. Most websites to tend to round up but....
The LC was only 1013.3kg because 186 vs 202.Last edited by CA18escort; 10-11-20, 08:22 PM.
