    Here you go, no buffering
    https://www.youtube.com/watch?v=GwchMlOUQ4o
      I’ve always had buffering issues with Vimeo no matter what device, OS or internet connection.
      6L FD3S RX7
      GR Supra
        Al, the president will have originally had a signal from the ecu to that control module that kept the fuel pump running while the CAS as giving it a signal, it starts and runs at first because there's a timer circuit built into it for priming.
        the factory wiring will have a constant 12v with ignition, and the pump is switched on the earth. that oddball looking wire is a coaxial cable, it's just the power and earth, i have no idea why they felt the need to shield it.
        if you use the haltech's fuel pump output to trigger that relay and leave the rest of the wiring as is you should be golden.
        (this is all based on r31 wiring, aside from the module being integrated into the ecu in an r31 it all seems exactly the same)
          Yeah, this. As i posted on youtubes: "The relay is a fuel pump safety switch and runs off either the coil or the RPM output from the ECU. The other box has a simple 555 timer setup in it. It’s the equivalent of the old Circuit Opening Relay in the Crown or AW11"
          Also for those looking for Ford 2 wire IACV plugs without tails, as I sent to Al and Woody, then they are Sumitomo HX 090 series connectors, and available from Eastern Beaver (yes, legit site) https://www.easternbeaver.com/Main/E...onnectors.html
            Eastern Beaver you say.......
            This is serious mum!
              We've bought stuff from him. Definitely legit. Definitely not real beaver.
                Yeah. It’s legit. But hilarious.
                  I have to say I'm really enjoying the President series on The Skid Factory
                    i know and i cant believe the owner put a carb on it originally, he musn't know anything about cars
                    www.holditflat.com
                      The scene where Al was pretending to fit the turbo was classic.
                        Originally posted by schnitzelburger View Post
                        i know and i cant believe the owner before Mark put a carb on it originally, he musn't know anything about cars
                        Ftfy.
                        And he was a retired mechanic, which makes me think it was a get it running and sell it kind of deal.
                          I'm quietly hoping that was a joke of the haha-only-serious variety. It's got a proper Haltech and a new fuel pump + injectors, all the ingredients are there to add a little presidential boost...
                          Norbie!
                            Al is good like that and can be very influential and help things escalate as he knows what you really want. Case in point, port EFI stuff for my car the recommendation was to get 1000cc injectors.....he's all about preparing you now for your future self/wants.
                              i know and i cant believe the owner put a carb on it originally, he musn't know anything about cars:
                              I think he put a carb on it so he didnt' have to tune it
                              "That which does not kill you, will make you very, very sick" - so says mizones mum
                                Silicon'd fuel tank is some exceptional dodgy shit. Generous of Al to refer to the disc of chopping board as a phenolic spacer.
