Datto 280ZX and Z31 2+2 300ZX IPRA Eligibility?
    Originally posted by Supashake View Post
    Sorry but theres no chance they will fit the cabin specs, Even 180SX failed that test.
    Didn't the 180SX fail because of a lack of headroom at the back? Z31 would be bigger inside I would have thought.
    ― Jim C. Hines
    ― Daniel Patrick Moynihan
    ― Napoleon Bonaparte
      Originally posted by I'm DJ! View Post
      Cabin specs.....fia measurement tests.....lobbying and building a case via relationship s....via the ipra forum. That was my only option when I started looking at the jza80 (no go)
      JZA80 would have to be the most unsuitable car for IPRA ever. Because restrictors. A60 would be better if going atmo. Or apply to have a UZZ30 added to the approved list and chuck in a UR. Would take cubic dollars, but all the front running V8s do.
        Pic of a Z31 showing the flattish roof line that extends back quite a distance, much more than say the 180SX which has a more curved roof line which drops down at the back and so would restrict rear head room. Anyway, where can I find the cabin measurements?
        ― Jim C. Hines
          The FIA tests go by cabin space by engine capacity. It fails. You've got a previous ipra EO here telling you as much. If that's not enough join the ipra forum and ask a current EO or, better yet, got
          to a monthly Qld ipra meeting and ask.
          Luckily for you there's also a class (Es) for sports cars.
            Join the forum so you have access to the technical section. I'm glad I did...it led to me aborting two different IPRA builds.
            Originally posted by IPRAFORUM.COM.AU
            Re: cabin size test...
            Post Number:#2 Postby TwinTurbo » Thu Aug 21, 2014 6:09 am
            Firstly any car Group A Homologated is presumed to be a Touring Car and hence to pass the requirements. So if the car you are considering is Group A Homologated then you don't have to measure it. If a car doesn't have seating for 4/5 people then no need to measure it, it already fails the initial "is it a Touring Car" test.
            There are a number of minimum dimensions that are dependant on engine size, ie; smaller engine size smaller dimensions. In IP for the dimension test we consider the smallest engine the car came with from the manufacturer. The relevant dimensions are the distance between the brake pedal and the centre of the steering wheel, the centre of the steering wheel to the rear window (parallel to the floor pan), the width between the front doors across the front seats and the height from the rear seat cushion, when compressed by the FIA approved weight, to the roof, with the headlining compressed.
            For first time IP recognition a vehicle has to have an application form completed that has a section for those dimensions to be included. They have to be confirmed by an IP Eligibility Officer prior to submission.
            If you PM me your email address I'll send you the application form.
            Cheers
            Gary Cook
            IPRANSW Eligibility Officer
              Yeah, join ipra forum
                Rear head height is only 1 requirement, You also have width across front and rear seats then theres the real hard one that even S14 and S15 JUST met, The measurement from rear seat to steering wheel then down to pedals. Get a copy of the cabin dimension sheet and try for yourself, Then theres the CAMS approved weight has been harder to find than a Martian whore. Needed for Compressing the seats.
                Is the Car Homoligated as a Sportscar? If so I don't think you have the same Pull Mr Moffat had in the RX7 Era.
                IPRA is frozen in time it seems so any change will take the old guard Dieing out.
                I remember someone trying to get 260Z 2+2 through without success on a few levels.
                GURU ENGINEERING PTY LTD
                  That said I'd love to see Old Skool Datto/Nissans in every class.
                    OK thanks blokes, will join the IPRA forum.
                    EDIT : Need to be an IPRA member to join the forum.
                    ― Jim C. Hines
                      That's strange, I never have been. You need to be a member to get access to the behind the scenes section, sure you haven't clicked on the wrong part?
                          I am a member of IPRA and on Vic committee
                          If you are serious fill out form and put you will be joining in the future
                          I will send the mods a pm to vouch for for you ....but as Steve says don't think your going to change the game it will not happen ...choose your car and come have some fun ...Ipra has a great bunch of members Aus wide
                          John P
                            Nah, just enter 999 as your member number.
                              What Dave said above. It's to stop random fuckwits joining and spamming the place...
                              I haven't been an IPRA member since 2008. They haven't kicked me out yet...
                                Theres a very quick ex rally Datsun 240K for sale up Sunny Coadt area, that'd meet criteria,,,,
