Fume/Gal Poisoning
    Originally posted by Ben. View Post
    Drinking milk is supposed to coat the lungs or some shit, that's why you can cough up some phlegmy shit after drinking heaps. The idea is that the phlegmy shit grabs all the bad stuff and you either spit or swallow it rather than let it rest on your lungs.
    Top idea to coat your lungs with milk. Helps with the Gal poisoning bad a poor side effect is that you drown. :knock:
      Originally posted by fezi View Post
      Bet that costs millions. Air wash hoods cost a couple grand as is. Speaking purely as someone who welds shit at home, I can't fit anything under my mask and still see out of it. Granted it's not a super expensive jobby, but its auto tinting which is pretty flash as far as im concerned.
      Usually I just try to have the breeze blow away from me, but still get a gut full of flux at times.
      I've never said or implied everyone on that page was a deadshit - just that there's a concentration of deadshits there. Think of it like a mine, but instead of a rich vein of gold bearing quartz, it's a rich vein of spastic bearing facebook posts.
      Originally posted by Sketchy
      Any peanut who thinks they could have done it better from the comfort of their armchair or work desk is a genuine mong level potato.
        Milk is to get the metals out of your body.
        Metals are not readily dissolvable in water. They form chelates which are deposited in fats (hence the milk).
        Same for the heavier metals, but you need an injection of the chelate formula into your butt cheek.
        Zinc breaks down and leaves the system naturally quite quickly.
        tl;dr
        Don't breathe anything that isn't air.
          Bit of fluid in the lungs never killed anyone.. Oh wait...
            The hobbyair systems are really cheap for how often they would save you cartridges from BOC.
            Side effect is that they dry the heck out of your lungs and get in the way
            now with extra gearbox'y goodness
              Bloke I worked with had a Speedglass setup... Upwards of $2k or more I think!! My helmet, on the other hand... $75 lol
              However... He's also an epic boily.. I'm an absolute noob! Funnily enough getting a new (if cheap) helmet made an awesome difference to my welds... Being able to "see" your welds, and therefore work it properly turned my beads from pelican shit to actual welds :D
              Originally posted by thecrackfox
              I wanna put you in a dress and hurt you...
                I looked at Speedglass. Price ranging from 1700 to 2600. Too much. Arranged to borrow a fume extractor on Monday before I weld the next 90 or so flanges.
                  Yeah, automatic lenses are fucking epic huh?
                  Just have an industrial fan set on high six inches from your workspace.
                    Makes a huge difference. Boss was helping me set up a job... Looked through the helmet I was using and said "fuck me dead you can't weld with this shit"... Went and grabbed me a Renegade helmet (cheap but all I need lol) and said "give this a go".
                    Being able to see the puddle and its relationship with whatever you're welding is great.. As I said I'm a noob: 20 years as a leading pressman and I swapped over to boilermaking maybe two months or so ago. It's a good feeling.... Starting with some bits and pieces and building stuff Wanna learn to Tig as well and build a few things for my cruiser (exhaust/snorkel/airbox etc).
                      At very minimum, rig up a ladies hair dryer, on no heat, low flow, into a length of 2" diam flex hose/vacuum hose, steap hair dryer to youpa belt, at your back, and run the hose up under your shirt pointed at your chin, the airflow up and into inside of helmet will keep gasses out, head cool.
                      Even if you prep/grind the gal away from welds area, the heat still cooks it out leaving the white powdery residue.
                        you using jigs or turntables to tack and weld those flanges?
                          Yeah I wanna learn TIG as well. I learned to weld years ago using an oxy on auto steel, so I reckon I could probably riddle TIG.
                            Wouldn't a man's hairdryer blow harder? /italics
                              Tack? No
                              Weld? Yes. I use a rotator. Best piece of machinery I've ever bought.
                              Shame that after I've made it sexy it gets hot dip galvanised.
                                Jesus it's not that difficult. Just a fan to pull the fumes away from you and out a door or window is enough for part time welders.
