    Starting with an open chamber U67 L20B casting - it doesn't really matter which head I started with as long as it is a big port one, you'll see why in a sec.
    Aiming to make a really, really powerful 2L datto:
    Got it all stripped down, seat inserts & guides out back to a bare alloy casting, then out with the TIG welder & spend a couple of hours making rods disappear:
    Snip some time while I straighten out the head (bent about 1.5mm from all the welding), then on to the mill, rough the welds down to .040" from the original face & then peen the bejesus out of the welds to compact & work harden the softer welds:
    Mill it down to a clean surface:
    Top face gets a light skim to get it nice & flat:
    Same goes for manifold face:
    That's that bit done:
    Now I've got a clean slate casting to play with, I'll be putting in my own design combustion chambers & doing some other stuff as well, I'll post some pics as I go.
    Definitely subscribed to this one, before and after pics will be the go.
      unreal amount of work. For a race class I assume not street?
        What cc in the chambers are you aiming for?
          These are always my favourite threads TK
            Whatever is required to get 14:1 comp........
            Yup, racer, gonna show em how it's done with an ol datto.
              excellent..
                That's going to run shit mate, I'd clean it up a bit before assembly.
                Originally posted by Mr Jones
                Sneakers prompted the erection. Engine stand made me do something with it
                  Come on he wants to bump the comp up
                  I agree with Rdyno
                    Is this what "twin swirl" combustion chambers look like inside????
                      holy sheeeet subscribe
                        I went through this in the 80s with my Group G rally 1600. I had an FIA Round port head tho. I had no problem out running the Works Stanza in a Straight line.
                        Just can't kill a well built L20B. I used the Aussie block and ran 160thou oversize bore and 13.2-1 comp.
                        The thing ate an FJ20 Gearbox every event.
                        GURU ENGINEERING PTY LTD
                          E85 for sure?
                            Subscribed
                              Same!
