One of these days I'm going to get you to see what you can do with an Alfa twin cam TK - they have it all - crappy short side radii, hemi chamber with no squish, and symmetrical ports so they've got virtually zero swirl.
Originally posted by Gammaboy View PostOne of these days I'm going to get you to see what you can do with an Alfa twin cam TK - they have it all - crappy short side radii, hemi chamber with no squish, and symmetrical ports so they've got virtually zero swirl.
Intake port:
Final head flow numbers:
The left side is with a radius plate on the spigot, right side is with the carburetor and stack. Lost about 8% of flow at peak lift with the entire system in place. Nick said anything under 10% is acceptable but less would be better. Still super steady on the bench, moving only .1 of an inch of depression at any given valve lift.
Intake valve: 1.900" (~49mm) (~1mm larger than stock)
Exhaust valve: 1.475" (~37.5mm) (1.5mm smaller than stock. Also the valve has been sunk to help with overscavenge issues)
MCSA is at the carb throat-the flange: 1.77sq-in (38mm dia). Hoping the motor will peak at 7200rpm.
Both the intake and exhaust have 50* valve seat angles. Again, we are trying to minimize overscavenge, and let the ports "ramp up" at around .250" lift... which they do.
Nick still has another spare head. Someday, I'll have him work some squish into the combustion chamber, and we'll do a clean sheet as far the the MCSA size and location. One of the issues he had with this port was running out of casting thickness on the sides of the port... especially where he was trying to blow out the short side radius to get air to turn around it.
Yeah, they're now doing crazy pistons like this to get squish into them - each piston is different because of the offset bores in the 2 litre (Bore spacing doesn't match chamber/port spacing believe it or not). This is a 12.5:1 slug.
Back on to this after clearing out a set of mild port 308 heads & a set of subi B4 heads.
Cam arrived yesterday, so I refaced the rockers & dummied it all up - less dicking around to get the geometry right than I was expecting, the longer intake valves are going to work spot on with a stock lash cap, the stock length exhausts need a .210" lash cap - coming over night from Stuart Wilkins.
Once that was all sorted I machined the spring seats in the head flat & checked spring installed height - intake needs .200" of shim, exhaust only .075" - found some crane spring locators that will only need the ID machined to fit & are .060" thick, so I can use them to locate the springs & add shims underneath to get the installed height bang on.
I'm calling that a win - 2x big unknows that could have been trouble sorted within 2 hours.
Now I'm pretty close to being home & hosed, gotta mill the head to final thickness & dummy it up on the short motor to check piston to valve clearance - which I think will be fine, due to the deeper chambers compared to the old head I have more valve free drop & due to offsetting the head the valve reliefs in the pistons will still work with the larger valves.
Gotta check anyway, but chances are we'll be fine.
No pics for now, going hard until I'm 100% sure nothing is going to trip me up at the last minute!
Originally posted by hoffman900 View PostHere's a modern Chrysler Hemi piston design (Diamond, but Racetec and CP also are being used by the top Hemi racers)
Originally posted by Rdyno70ynu has to be the most retarded cunt here. "Help me please" me "you need to remove your head" him "fuck off cunt I'm to lazy fuck off out of my thread you told me to do something I don't want to do so you're a cunt fuck off can some one please tell me an easier way???"Originally posted by TripperIts a tight battle between you and rogercordia for the most retarded member on here, thou i think you have it by 5 window licks
From memory I cammed that one with minimal forward split & tight lobe centres (105), duration was late 260's/early 270's & lift was around .600"
No, it's bigger than a 1308a & is not a single pattern like most datto cams, has more exhaust duration but less lift.
It was custom ground to my specs.
Fixed piston to valve issues - a little touch up with the grinder was required, all good now.
Time to look at individual rocker arm setup to make sure each valve gets the same lift & duration - small changes in tip height & rocker tolerances can affect things more than you'd think on a finger follower type setup.
Here's one for the Datto heads, with the contact pattern in the middle of the rocker pad I had .572" lift with .012" lash, messing around with tip heights & having the contact pattern off centre (but still well within the pad) we've gone up to .592" lift.
You have to set each one up individually to suit it's rocker arm, .005" tip height makes quite a difference to lift & also affects cam timing - advancing or retarding that particular lobe compared to the rest.
If you don't do each & every rocker & valve tip you can end up with effectively 8 different camshafts in the same engine, which never works out that well.....
