    Yup, E85, datsport intake & 45mm TB's.
    It seemed to me that the head bolt holes would be better off about 2mm further away from the manifold face, so that the head sits off to the side about 2mm & get the intakes valves closer to centred in the chamber at full lift.
    You'll notice I welded up some of the water jacket holes on one side, that's to allow the head to move over on the block a bit.
    I started offsetting the head bolts holes in the mill with a core drill, but it wasn't going to work - too much flex in the drill, so I ended up just doing it by hand with my grinder, not the prettiest job, but hey, it'll work:
    Next up I gotta finish stripping down the short motor (needs a freshen anyway) so I can sit the head on & mark out the bore onto the head.
      Got the short pulled down & the head dummied on the block, you can see how much I've moved the head over:
      Head face scribed with bore locations, you can see the offset in the welds:
        You fucking what?
        Your raw talent astounds me mate, top work!
          Sub-fucking-scribed.
            Subscribed x11tybillion, my L18 is green with envy.
              has the owner talked to you about offset crank grind destroking the other motor a little TK?
                U at work tomorrow? I'll get the closed deck 25 dropped off.
                3D scanning
                3D modelling
                Structural certification
                3 and 5 axis milling
                  Allan - yep, but if I can crank this L up hard enough the other donk may get sidelined for a bit.
                  Alex - cheers, haven't had the chance to grab it yet, the hurry on it backed off a little but gotta look at it soon
                    VQ35 Parts are here from Jim Wolf, ITBs are with Customs so you should see them all next week Tony.
                    GURU ENGINEERING PTY LTD
                      Subscription.
                        Fucking Awesome!
                          Amazing that such a thing is done, and who thinks up doing this kind of work on a head. I thought a cnc routed head was cool, but this is better.
                          Look forward to seeing the big torque figures. Do you have power figures for a similar combo motor build with more conventional head? So you can compare to this head.
                            with the head bolt holes what about using offset hollow dowel/bush type things (thinking like a camber adjustment bush thing) or wont matter enough to go to that length?
                            the amount of information you give away on here astounds me, I guess people would need to put talent together with information to be competitive with you however it is still unusual to see this level of openness
                              Looks like a TK vs Munyard challenge. Looking forward to seeing the results.
                                TK, when you were welding the head, what sort of amps were you using?
                                I daresay most 200a welders wouldn't be up to the job without lots of preheat and a watercooled torch?
