    I've got another junk U67 casting here I'll take some pics off for a before/after comparison.
    This motor will be going on Bill Hansons engine dyno in a couple of weeks, so no guess work as to what it makes.
      Amazing! When doing it all by hand, how to go about making each of the chambers/ports the same?
      Experience, practice & measurement.
        Gotta smash through a freshen up on a set of subi heads this morning, then back onto the datto this arvo.
        Hey did almost loose his hand in a machine, maybe he got the doctors too upgrade it.
        It got downgraded a bit, I have to take a 10 min break every hour or I pay for it bad at night, probably a good thing tho, before I'd just grind for up to 4 hrs without a break, long term that's not a good idea!
        My thumb still has limited movement, it's settled down to maybe 50% of normal movement, fortunately the movement it has is mostly in the arc I need it to be in!
          Scratch that, need a cam & seals for the subis, won't get them till tomorrow, so datto is go for this morning.
            Chambers all done bar final sanding - I'll do all the sanding at once when I'm done with all the carbide work.
            Took a few pics of the junk head, it's been messed with & cut for bigger valves, but you get the idea:
              Nice, that looks really similar to what i've seen done to pug 205GTI heads. Except the spark plug position on the pug isn't as nice as that.
                Cylinder head porting porn. Outstanding.
                  Grinding, plus a bit of grinding & some grinding
                    Top work, absolutely fantastic.
                    I also love how they look like derpy faces...
                      Great work TK!
                      1970 RX2 coupe, 13b turbo.
                      1973 Cortina, 5.0 Windsor
                      1974 808 sedan, 12a Bridgeport
                      1976 Datsun 260c Coupe
                      I've got a 1968 XT Falcon.........!
                        special hi performance spark plugs
                        Originally posted by 50RTD
                          Intakes all done bar sanding, nothing new there so no pics.
                          3x exhausts to go, then on to the intake manifold - I'll have to relocate it higher up on the head & dowel it into position to get a straighter shot down the runner.
                            Is that a crack?
                              Where? I see scribe marks and a few scratches that will disappear when it gets skimmed at the end. Oh in that left hand water jacket. Hopefully just a scratch.
                                From just left of centre up and into the chamber. (It obviously isn't, otherwise people far smrter than I would have picked it up)
