    Looking to replace my single cab rn85 hilux with an rzn149 hilux I want to swap the tray from my car to the new one because it is a hydraulic tip tray. Are the mounting pints on the chassis in the same place? Is it common across different brands even so maybe a bravo or courier etc?
    Originally posted by Marv
    "The bitches," he proclaimed, "are wet"
      Originally posted by horrace View Post
      Centre caps (plastic) on my 2008 WRX daily have the paint flaking off. What the hotness in matching the colour? is there a code to be found? The wheels themselves are immaculate bar the centre caps
      Have you looked at what new ones cost on eBay? If they were Volvo ones I could prolly get ‘em delivered for less than the cost of a the required rattle-cans.
        Need to run some longer low pressure power steering lines around the engine bay and looking at hose prices. Is it just me or is it hard to buy a “light duty” oil safe hose these days? The larger of the two will need to be 9/16” ID which really won’t route or turn corners well in 2000psi rated hose (and costs a shitload).
        Am I better off doing it in alloy bundy tube? Don’t want AN fittings but will need to add a bead I guess. Other line is 5/16” ID.
          You "might" be lucky and there's no changes but generally they're different. Also depends on the mounting method of the tray if there's any wriggle room.
            Single and dual cab are different. But the chassis is relatively the same, and with how they make trays you should be able to just remake the mounts.
              Where from?
              My elderly neighbour has a V60 wagon that has lost it's centre caps. They always help me out so I'd like to get them some.
                Where from?
                Just eBay, I doubt they're genuine but they seem to work (annoying rattling being a side-effect of ill-fitting cheap centre-caps).
                  Appears to be nothing for my subie on there unfortunately
                    Extended rear shackles, is this something I can fit at home with just a scissor jack ?
                    Figuring I can leave the vehicle on the ground and put the jack between spring and chassis rail.... remove old shackle, wind the jack up a bit more and fit the new ones, or am I missing something ?
                      You could be missing something if the jack slipped. Like a hand, or a head for instance.
                        yeah I would not have either between the spring and chassis rail, I'd be behind the spring at the rear.
                          Just do it properly. Put the car on stands and replace the shackles when there is no load on them.
                            if I had the equipment to do that I would not have asked the question, A question which asks is it possible, not if it is dangerous.
                              Definitely possible.
                                By that method of thinking on a very similar line, yes it's possible to crawl under a car using just a shitty scissor jack. Would you do it though?
