    Quick 1JZ question. Say you whack on bigger ic, injector, wind the boosts up, dump pipe etc. Will the factory EC happy run, or would you reflash (can Toyota 1J ecu even be reflashed) or need to run aftermarket engine management
    just looking cheap and cheerful solution. But if requires a new ecu do have a ps1000 spare.
      If you're worried ring the mechanic and ask it's it been abused or just wear and tear.
        Can't reflash Toyota ECUs. If you change the injectors you either go with a piggyback or get a real ECU. Since you have a real ECU, problem solved.
        Norbie!
          What’s the hotness in wrx td04’s and/or upgrades? Mate has a td04L I think, it’s getting a bit tired. Likes the response, wouldn’t mind a touch more top end.
          I figured a modern version of the td04 would be good, it seems all the ihi stuff seems to add a bit more lag (but lots more top end)
            I used to have a GT Pumps Turbo on my STi, it went good. From memory it was a GTPS02 (this over ten years ago)
              Seeing as we are on the topic of the 1jz. I have just installed HKS cams and HKS timing belt on my non vvti 1jz and now have a slight supercharger like whine coming from the belt. I replaced the tensioner and idler at the same time. Should I be concerned about the noise?
                That usually means the belt is a bit tight, but that's coming from stupid french cars where you have to manually tension the belt. With the auto tensioner I guess all you can do is double check you do have the correct length belt.
                  Holset he221. Some variations you can fit the chra straight into the td04 exhaust haousing, but they are good for roughly 380hp
                    It was tight to get on but so was the one I replaced. Checked it against the one I replaced before installing, same length and number of teeth.
                      been getting a lot of bugs on the windscreen, whilst easy enough to wash of with a soapy sponge removing them with the wipers is a different story. Have tried various different solutions in the wiper bottle. is there any coatings that i can put on the windscreen that will make it easier for the wipers to remove the bug splatter
                        Tried Bar's Bugs?
                          Yes tried bars bugs honestly there doesn't seem to be much of a difference between the various additives.
                            Bars works with a higher ratio against the south of Perf midgie invasion. But it does leave a stain on the area behind the sprayer.
                            Try coating the windscreen with Wet Coat or car wax. it makes it easier for the bugs to come off with wiper wash.
                              What about something like RainX?
                                There used to be a product called ‘Bug Off’. I used it once on my AW11 - ate through the clear coat on the bonnet in one day.
                                I use water now.
