    I have a car which is two tone. The build plate lists the exterior colour for the top half only. How do I find the paint code for the bottom (aside from taking a panel to a shop to colour match).
    Giving VIN to dealer doesn't list the colour.
      Sometimes the paint code lookup program lists the secondary colors. Panel shop or paint supplier might be able to help you work out what it is.
        Sales brochure from back in the day? I've seen paint colour codes listed on enthusiast websites.
          What is the car, and what's the top-half code?
          [and it's not the a two-tone code is it?]
          Hard to believe The Internet Of Nerds can't sleuth that one up.
            Anyone know what the control module thing is for on VF Commodore thermofans, assuming it has relays in there. Will it be of use for any other vehicle needing a thermofan conversion?
              I'm planning on using a VF V8 thermo and shrouds. My plan is to throw the controller and use a Davis Craig fan controller. What am I missing?
                ^ can't get a brochure sadly
                code on build plate is 051 Toyota which is white pearl. It's an old Lexus with 2 tone.
                  Was just thinking if it has the relays inbuilt it might be a neater way to go rather than installing another two relays like you would normally have to do. I have no idea how that VF thing works it most likely communicates with the main ecu.
                    Box of mystery, from a wiring loom conversion mate. It "might" be like late model alternators that use ecu input to regulate, otherwise just stay on
                      ill leave this here
                      Paint Codes.pdf
                        I'll dig around a mates VF.
                        GM uses a BCM ECM and "Electrical Control Centre" in the car I'm throwing it into. The ECM sends a sends a signal to trigger a relay. I'm not fucking with the ECU so will use a external controller with it's own relays and temp sensor. The complete Davis Craig setup cost me $100 last time I bought one and works a treat. Plug in hot, ACC and ground. Connect temp sensor and you're away. You can even dial in the temp when it is supposed to turn on.
                        I know the late model GM cars use a variable fan speed controller. But fuck knows what Holden did.
                          I went Googling for this last night & failed ... however, Lexus is very Supporty and Lexus dealers undoubtedly sell touch-up paint so maybe worth calling one?
                          As long as you have a non-import VIN.
                          [even without that they may be helpful]
                            Will be using aftermarket ecu to control fans anyway, just curious to know what the VF module is and if I can use it in anyway.
                              it's one of those cars which came in under the 15 year old rule from eons ago. no dealer wants to touch it but I've narrowed it down to 2 shades so i'm hopeful thats it
                                If it's like some manufacturers, it just has the big power/earth wires, then a single wire for PWM control, the module then does it's magic to supply the required airflow.
                                Originally posted by ALLMTR
                                Yes but more power is the solution, even if lack of power isn't the problem...
