Originally posted by takai
View Post
Originally posted by Do the safety dance. View Post
Same.
I'm actually on the look out for one for a mate, if anyone comes across one.
Originally posted by RdynoIt's fucking storytime with Rdyno cunt shut the fuck up and fuck off.
I wonder what result you’d get if you sent the ViN to Ford to get the “as built” sheet on one of those Nissan Utes?
Would be even funnier if some tragic had nicely restored one thinking it was a Ford, then gets the Build doc and discovers it’s a Nissan
How hard is it to change a set of SBC heads? I've removed/replaced heads on 4cyl ohc stuff before but never on a pushrod thing and I'm oddly intimidated about weird stuff like getting pushrod lengths right...
Specific scenario: 350 truck motor, stock except cam and carb, hoping to remove heads, ignore bottom end, bolt on new aftermarket off the shelf assembled heads and bump compression and improve flow, all without removing the engine, and hopefully feel like I haven't wasted my time at the end of it.Last edited by Fraud; 02-11-20, 08:20 AM.Originally posted by myshortyboombaI've had many gauges in cars. I always found the conrods react faster than a gauge.
Originally posted by Fraud View PostHow hard is it to change a set of SBC heads? I've removed/replaced heads on 4cyl ohc stuff before but never on a pushrod thing and I'm oddly intimidated about weird stuff like getting pushrod lengths right...
If it's a SBC (non LS) I'd go with a complete combo from Edelbrock. You get a power up package that includes the right cam, push rods, inlet, fully assembled heads and if you want, even the carb and airfilter. -> https://www.edelbrock.com/power-package-top-end-kits
Summit racing says you're looking at about $1400 plus state tax as a starting priceSent from my shed, trapped under a collapsed QuickJack, via Tapatalk
Thermo fans - specifically, really low profile/slimline ones. Are there any any OEM puller fans in 10-12" range that are around 60mm thick? Ive got max 60mm between radiator core and snout of water pump. Tried a Chrysler Neon one that looked really thin but got caught out by the fact the fan protrudes 10mm UNDER the shroud [yeah i know, rookie fuck up]. Anything spring to mind? Would rather OEM because they are pretty much no-bullshit in terms of CFM they can move plus its going to be a hell of a lot cheaper than forking out for a Maradyne or SPAL. MUST be a puller fan because...reasons.
Firstly, what car/truck is it in. Space helps.
Edit, I read you post as working on the engine still in the car.
I was looking at full top end kits initially, I started trying to talk myself into a hydraulic roller retrofit as part of it and when I did the numbers an LS swap or crate motor started looking like real good value so I gave up, but I'm getting itchy feet again and wouldnt mind some kind of project over the next few months, especially if something comes up on black friday sales.Originally posted by myshortyboombaI've had many gauges in cars. I always found the conrods react faster than a gauge.
To add to the above, I've read that adding new, better sealing heads on an old motor without giving any attention to the bottom end is likely to lead to premature failure of the rings and lots of blowby and/or some other failure.... Truth? Age/mileage of the current motor is unknown as the instrument cluster was swapped out a while back, but it's gonna be ~120k-150k miles...
I'm not terribly upset if I do end up needing to give the bottom end some love at some point, I just don't want that in scope right now.
Whether I want to go to the trouble of all of this vs an ls swap or crate motor is a whole other thing... But the space I have available for diy type work doesn't really allow for engine cranes and whatnotOriginally posted by myshortyboombaI've had many gauges in cars. I always found the conrods react faster than a gauge.
