    Do I need to paint over rust convertor are can I leave it?
    Google giving conflicting advice.
      I always paint over it, but thats typically because I want it to look tidier, but I think that painting over it would surely protect it from future degradation?
        whats the current hotness in sites/companies to look for cars to import from japan?
          Paint over it, its only passivated not protected.
            I used J-Spec about 3 years ago and they were great. I'll definitely use them again. The only part of the process which sucked balls was the poor workmanship of the local SA workshop which the compliance was outsourced to.
              Thanks gents
                Tried to start Volvo yesterday - battery is on trickle-charger thingy as per usual, and it thinks the battery is OK - the attempt to start made a bit of a pissweak whirring sound like a fuel-pump not quite bothering, and then nothing.
                What's most likely, munted engagement solenoid in starter itself?
                  Measure voltage and watch it whilst trying to start first. Should tell you how good or bad the battery is (charged).
                  Remove your charger or power cycle it if it's something like a Ctek to let it go through the multi stage process again.
                    I always experienced the starter solenoid giving a hearty 'click' followed by nothing when it was on the way out.
                    How old is the battery, and do you have a multimeter you can put on it while cranking to see what's happening voltage drop wise?
                    You may find the trickle-charger thingy determining the battery's health is as accurate as those 'magic eye' indicators on the battery itself. Which is to say, potentially: completely inaccurate.
                      Hit it with a big lump of timber. Maybe it's stuck and will trigger with it...
                      Does it have a relay somewhere off the ignition to power the solenoid? It is an oddball Volvo after all...
                        I'm an incompetent & impatient noob, it's more oddball than your average Volvo.
                        I doubt I changed any of the starter circuitry (although maybe I did something stupid & knocked a wire off when removing the IAC yesterday).
                        I was carrying a 2x4 for 9 months or so in a stock one, for getting the fuel pressure-pump going, maybe the same tool needs applying to the starter. I've not driven it for quite a while because the idle thing was annoying me, and then we had a chance of rain daily for 3 weeks on top of that ... it could've been 2 months even since it's been started, I guess that could affect solenoid stickiness?
                          Or the battery is fucked. Very easily measured with a multimeter while cranking.
                          (Assuming you have a helper to try and start the thing while you hold the multimeter probes )
                            ^ No I don't, will have to use a pair of jumper leads for that.
                            A stuck solenoid will still pull current won't it? Any risk of burning something out, with that current not moving anything?
                              Don't hold it on start for long and don't leave ignition on for extended periods and it will be fine even on an old vehicle with a single coil, points etc.
                              If the voltage drops below 9 or 10 (ish) when attempting to crank, look at battery. If you cm have jumper cables you could try jumping off another vehicle. If voltage doesn't drop then I'd look at starter solenoid.
                                awesome, cheers mate
