    Originally posted by GreatWallGT500 View Post
    B Series falcon i6 heat shield- the one under the car after the cat.
    Mine seems to have come loose on the edge and is rattling at certain low rpm but fucks off eventually although it's getting worse.
    Best way to fix this on the cheap?
    Or should I just remove the cunt and deal with a bit of extra heat?
    Bend it away from wherever it's touching.
    Originally posted by brewdles
      A weird one probably for Jack Nicholson but did we get the supercharged 4.0L Jag XJ6s in Australia?
      Or anyone know what the part code is for the alternator is on those? Apparently they are a swap in 120A proposition for the 3RZ.
        Can anyone recommend somewhere to get a decent radiator for an '02 subaru outback? The one in the car is only a couple of years old and it's been weeping from the end caps for ages already...I can't remember where I ordered it from but it was probably a cheap generic piece of crap from ebay or sparesbox or something. Do I need to lube up and get a genuine one from subaru?
          It's coming apart at the seam so its vibrating against itself.
            Originally posted by nastysven View Post
            what size are the gearbox bolts on a VT 1 304?
            Need to get one on an engine stand.
            Cant multiquote for some dumb reason but faux forg is right. 3/8" UNC
              Can't help with the part code ... but it depends what era you're looking at?
              I don't think we got anything that was badged XJ6, but the '94-'97 XJR here had the 4L supercharged (6cyl) engine.
              Last edited by Captiva Fan; 07-04-21, 09:06 PM. Reason: Added confirmation of the 6cyl bit as I'm pretty sure the '97+ had a 4L V8 supercharged engine
                Not quite. After the overall diameter of the housing, like this:
Name:	Screen Shot 2021-04-07 at 2.45.05 pm.png
                About 180mm (can't measure exactly due to inlet) for a GTX3582R gen 2, I think the housing is the same size.
                Might be able to figure out something from the tech specs.
                  Get Fenix from foamy
                  Subarus chew threw radiators but straightforward to replace. They blow out the tanks, even with genuine,
                    https://www.ebay.com/itm/1995-1997-J...-/264690764595
                    Originally posted by Marlin
                      Right, so XJRs seem to have the same alternator. Part codes 101211-7640, LNA-1800DA,LNA-1800BA from the US sites.
                      $700-800 here... back to the drawing board.
                        Have a look at Prados with the same motor.
                          Bunnings in the fencing isle and get some 0.8mm stainless wire and wrap a few turns around the shield and twist together.
                            Look at 1GRFE alternators.
                              Originally posted by Faux Forg View Post
                              Pretty sure they are 3/8 UNC
                              100% correct
                              Dr Hoon
                                Prados are the same alternator, 70A.
                                1GR alternators have different mounting points:
Name:	Screen Shot 2021-04-08 at 10.55.23 am.png
