    Auto oil works decent too.
      Why not just leave the sludge where it is?
      Originally posted by Marlin
        should i do this on a car that's going to have its rear main replaced shortly anyway because the gearbox is coming off?
          There is no sludge in his engine
          But if there was, cos it blocks the oil passages and thus no oil in metal on metal areas
          "That which does not kill you, will make you very, very sick" - so says mizones mum
            Let me rephrase that. I don't think using a chemical product to break up sludge is a better option than just leaving it be. If it's there, I'd rather it be stuck to the sides than floating in the oil. That said, I change my oil about twice as often as the book says to avoid those problems in the first place.
            Question that doesn't deserve a thread: Waht's the deal with fuckin' 79 Series Cruisers getting the death wobbles at ~80km/h on smooth, straight, sealed roads?
              4" narrower rear track compared to the front?
                When you see it, you’ll shake your head.
                  Seems a few 4x4s do this, older bt50 will get a bit with natural frequency around 90km/h. I'm pretty sure it is a mix of tyre construction, toe and interaction of scrub radius, king pin inclination (camber/castor/trail) and non ideal Ackermann angle. Real irritating. Went in a heap of circles chasing balance or wheel run out for a while.
                  Track doesn't matter.
                    If a 4WD isn't engineered to suck, it's scorned by the 4WD'ing community and they won't buy them.
                    Ever see an Audi R8 V10 offroad? No, you don't. And it's because the 4WD community hates them for being too pleasant to drive.
                    PS. 80-series Cruisers used to do the same thing, seemed to be from around 100km/h though. Same with GQ Patrols and the square models of Pajero. I assume this was just normal in 4WD's (including Japanese utes - 2.6L Rodeo was the same) until ... I dunno, have they stopped doing it?
                      Ohh, OK, yep, get you now. Yes also a fan of doing more oil changes to prevent this
                        Need to do the water pump and timing belt on the 7afe in my old corolla. Will I die or throw spanners ?
                        Originally posted by 50RTD
                          Not enough castor usually. Possibly too tall a lift with no correction or flogged bushes. Our old Land Rover had epic death wobbles which would be triggered by hitting a bump a certain way. Ended up needing new bushes and castor plates, was a PITA because being ex army it had extended shackles which make the issue worse.
                            nah, its pretty straight forward. have to get a couple things out of the way but its simple enough to do at home.
                              Legend. Yeah, need to pull most of the things off the front. Old girl done 290k so needs some loving
                                nope, I did my Holden Nova one no worries after the stocker snapped, thankfully non interferance. I'm mechanically retarded and have a short fuse and no lawnmowers or walls were stabbed with screwdrivers.
