    the water pump pulley is tight to get off with the chassis rail. Or maybe that's the 4afe.
      Its all the A series engines in FWD. From memory the later chassis had slightly more room, but not much.
        QQ - AU Falcon - heating/aircon started smoking into the cabin? Not my car, but gut says something on the heating element that's going to catch fire?
        When too much horsepower is barely enough
          While we're on A-series engines; are the starter motors for 4AGE/4AFE/7AFE and so forth largely interchangeable?
          Need to replace the one on the AW11, and the collective knowledge of the internet seems to be yes/no/maybe.
            Leaves caught against the fan resistor in the heater box.
            Pull the glove box out, where you should see the resistor at the bottom of the heater box. Remove it and tr and vacuum the leaves out.
            Assuming the smoke smelled like leaves...
              ..or rat/mouse/whatever
              Still blows me away modern cars have a hot wire resistor in the air stream
                Thanks you, that makes sense. Someone is going to have fun pulling that apart!
                  On FWD engines, yes. The later ones are better for torque though. Earlier ones are interchangeable to later cars but some of them have fouling issues with various exhaust manifolds.
                  RWD starters foul most FWD exhaust manifolds.
                    Thanks. From what I can work out will be the FWD version.
                    There appear to be two different spots they mount on the bellhousing, but apparently it doesn't make any difference.
                      Yeah, same bolt spacing regardless. Does make it easier if it fouls on certain headers though.
                        Anyone know if rollover protection (ladder rack directly behind the cab) is a legal requirement for a ute?
                          For general use, no. For mine sites and some industrial sites, yes. A ladder rack is not an approved ROPS.
                            Ok thanks, I was thinking that it could be an ADR requirement but if it's not even better.
                              That frame behind the rear window on utes is simply to reduce the chance of somthing going through the rear window, most certainly NOT roll over protection.
                                The one I'm talking about is more of a ladder rack usually used in conjunction with a rear one as well. I see the front one fitted pretty much as standard fitment on most trays, the rear is usually an option.
