    QN: reckon i need to put a fuse before a fuel cut defender? since its easiest to package it in the ECU box ill be taking +ve from the ECU power pin (+B for you toyota people)
    ordinarily i dont like to mess with a critical ecu power feed but the ECU box its the most convenient place to wire it and store it.
    www.holditflat.com
      So bloke at work is trying to restore his 2003 Prado and after some bits of trim, external and internal. Wreckers are no dice and Toyota wants him to buy a new Prado. Any ideas where he can start to look if eBay isn't much help ?
      Originally posted by val245 View Post
      Go to partsouq.com
      Legend, thanks
        Oil flush: does it do anything and is it just diesel/washing up liquid? used some in the nopics car the other day because it was already a million kilometres overdue for for a service and won;t be able to book it in any time soon and the guy usually writes on the invoice that he uses oil flush (it's direct injection)
        I've never used it before, corolla is due for an oil change and might use it but i'd rather not spend 11 bucks on a bottle of supercheap's finest if something else will work just as good. actually might just not bother.
          I use it on cars that are significantly overdue, I don't bother with ones that are serviced regularly.
          I reckon it does clear more gunk out.
            What corollas are direct injected?
              Current models are.
                I changed the oil in my nopics car which is DI.
                I also need to change the oil in my 16 year old corolla, which is not DI.
                  Not a 100% car question but does anybody know a good driver's road or route for a day trip within, say, a few hours from Gladstone?
                  Stuck here for work and get a day off soon. Would love to find a nice quiet, windy road somewhere for a sporting drive and some sightseeing.
                  Alternatively if there are no fun roads around what about nature attractions? Thanks PF
                    Can't really suggest anywhere for a sporty drive but what about a nice little day trip south to Agnes Waters and 1770? Stop at the Captain Cook memorial, Wander up to the Bustard Bay lookout, go for a trip on an old Army LARC
                      Good suggestion mate. Ive given up on finding a good driver's road and narrowed my choices to a day at Agnes or climbing Mt Larcom. Cheers
                        I'm sure I've asked on here before (outside this thread) but I don't think I got an answer and search doesn't give me much...
                        What's the deal with aftermarket blocks and rego/engineering etc? Let's say a dart SBC to replace a gen1/2 sbc...
                        Is it effectively deemed a direct replacement part, and you update the engine number and move on with life? Or would a 2021 date stamp make it a 2021 engine and cause headaches?
                        Does the answer change if it's supplied as part of a brand new crate motor?
                        this is more a curiosity thing than a burning need, and LS everything is the obvious answer, but let's assume I'm an idiot.
                          Blocks have date stamps now? I have only purchased a couple of replacement blocks and they usually just have the manufacturer serial number on them and you can stamp your own engine number to match your previous motor.
                          For the purpose of age/id number with transport/gov, they are only really concerned with emissions. If you took the engine apart and replaced every single component, but it went back together with the same emissions equipment and would pass the same emissions tests, I don't think they really care much what you replace in the motor as long as the engine number doesn't turn up stolen/duplicate in any checks.
                            any good led reverse bulbs ?
                            sure i could buy a small led bar, but its all on road use
                              Originally posted by Fraud View Post
                              What's the deal with aftermarket blocks and rego/engineering etc? Let's say a dart SBC to replace a gen1/2 sbc....
                              In WA you can replace like for like if the block is the same age or newer. So a 1979 car can have a 1979 or newer block
                              Old Ford V8's (i.e Windsor) for example date stamp engines in the valley
                                Not talking about OEM blocks having date stamps, talking about new aftermarket ones.
