    Mr Ree
    The best value-for-money option is to get an Apple CarPlay & Android Auto kit, it takes over the navigation menu in the touchscreen, you lose the factory nav, but you get the maps from your phone, as well as music, messaging, and all the other fun stuff that CarPlay or Android Auto gives you.
    I suggest this for several reasons.
    - The newest available maps are AUS22/NZ11, they are from 2016 (actually the map data is from 2015). There is nothing newer available.
    - Being an SG car, the maps are stored on a hard drive inside the head unit. The hard drive is encrypted. This is a different system to the Japanese cars that use a DVD, which would be more common in NZ.
    - You cannot simply install AUS/NZ maps over the top of SG maps. It won't let you.
    Your options are swap in a complete 2nd hand head unit from an AUS/NZ car, or to swap the hard drive over.
    Either is a "plug & play" scenario, but swapping the HDD over has one additional caveat, the head units were produced with a mix of SATA and IDE drives, and there's no way to know which you have until you disassemble it...
    And after all that effort & expense, you will still have maps that are at least 6 years out of date, possibly even older depending on the age of the donor car, & if the maps were ever updated.
    CarPlay gives you so much more for your money.
    Click image for larger version  Name:	IMG_3006.jpg Views:	8 Size:	976.4 KB ID:	7274740
    Originally posted by nutttr
      Thank you very much for that info Jack Nicholson
      Gutted to hear that the SG maps arent dvd loaded like the others...that has completely foiled my plan
      I appreciate and agree with your logical suggestion to upgrade to a new head unit, but the car is owned by my Uncle, who doesnt own a smart phone, and wouldnt want to have to learn all the technology to get it to work.
      On the bright side, at least we only have about 5 roads in total here in NZ so hopefully he wont get lost.
      Thanks again
        Ah well Mr Ree in that case, a head unit from an AUS/NZ car that has the local maps in it is the way to go.
        Like this https://www.ebay.com.au/itm/193254349958 I know for sure that was an AUS spec car (I do some work for those guys).
          Thanks for that link...thats great, at least I can give him an option to consider.
          Is it an easy enough process to load NZ maps onto the AU head unit?
          Ive installed dozens of car stereos over the past 30 years, but have never worked on a modern Jag, so Im not sure if I want to risk attempting the job myself, for fear of cracking wood grain trims hahaha
            The AUS & NZ maps are the same, you just go into the "state" selection and NZ is there, along with all the other Australian states....
            So just swap one head unit for the other.
            It's a fun job on an XF, would take me about 40mins, but I have done a few... I can get you the workshop manual pages if you need.
              Hahahahaha the far Eastern State
              That doesnt sound too bad in that case...I can take it slowly and spend an afternoon on it, if my Uncle decides to go this way.
              The workshop manual will be a lifesaver, I expect. Thanks again for your help
                Garmin GPS units have Aus/NZ as a single map with NZ as a state selection . You can download the map file and it has img file extension.
                  Wow, I finally have a good reason to post in the 8 ball thread
                    A mate of mine just picked up one of these for his old Alfa so he could keep the stock head unit, and has just put it in the choke knob hole.
                    https://nvx.com/nvx-xubt3-universal-...ller-knob.html
Name:	Screen Shot 2021-07-26 at 4.20.42 pm.png
                    Seems like a pretty sweet solution for an older car. Anyone used one?
                      How can I dispose of ~40 litres of stale petrol, during a lockdown? Is there some MacGyver way that I can mix it with gravox and sawdust to throw it in the bin?
                      Originally posted by Marlin
                        Mix with detergent and tip it down the dunny.
                        Far from ideal, but will work.
                        Dr Hoon
                          how stale tho, u dont have a daily shitter that'll take it?
                          www.holditflat.com
                            It's pretty bad. It looks like it has algae growing in it, and it killed the new fuel pump in the project car.
                              wow sounds fucked, have any neighbours that use their leaf blower way too much?
                              www.holditflat.com
                                Evaporation is your friend
