    Originally posted by Tripper View Post
    low profile trolley jacks for home use, whats the hotness ?
    I went with one of these:
    https://www.kincrome.com.au/1100kg-slp-garage-jack
    Expensive (400-ish) compared to the cheapies, and heavy enough (45kg) that it stays in the garage 100% of the time, but 68mm at its lowest, actually long enough to get under low cars, lifts quickly, very long handle. Most of the other 'low profile' ones are 100-110mm minimum or have massive ramps up to the handle area that make actually getting them under a car a massive PITA.
    Otherwise Costco had the Arcan 2T ones in stock last time I was there:
    https://www.costco.com.au/Automotive...2000kg/p/49927
      Richmon jack on eBay. Near enough to a Bluepoint/Snapon jack, at a quarter of the price. Been using one in a professional setting for the last 12 months. Can't fault it.
      Originally posted by brewdles
        Link for abovementioned jack.
        Best quality hydraulic floor jack 2ton low profile high lifting. lift range :Minimum:68mm, Maximum 600MM LIFTING.
          Is using regular sockets on a battery rattle gun a bad idea? Just the Toolpro 3/8" one.
            Depends on the quality of "regular".
            I've had cheapies split and they can fragment, but I do it regularly.
              Technically yes. In say 95+% of cases it's perfectly fine IMO. If you're really getting into some thing heavy duty like a crank bolt then yeah best to use a proper impact socket. Maybe wheel nuts too as that's something you might do a lot.
              I wouldn't worryand use regular ones all the time as a home DIYer
                I have been pounding away at my old supatool sockets with a Makita 1/2” impact wrench driving M12x200 coach screws in to old railway sleepers. Held up fine so far! Only because I don’t have a spade but to open up the counterbores any bigger…
                  Should be fine with a six point being driven by a 33/8". The reason they don't recommend normal sockets is the chrome plating comes off in high speed splinters
                    Thanks gents, I only have the regular 12 point sockets and 1/2" impact sockets. Might be better to get a 1/2" to 3/8" adapter for the sake of a tenner.
                      Anyone know what sort of coating this is? More importantly anyone know how crap it will be to weld?
Name:	Screen Shot 2021-10-05 at 11.03.29 am.png
                      Seems that the only ones which come in the combo im after (bleed valve on filler neck, 2.5L etc) have the coating.
                        looks like photoshop to me
                        www.holditflat.com
                          The sides do, but the top looks like it might be coated.
                            that's all photoshopped, they just did a very slightly less crap job of the top than the sides.
                            GT-P
                            Bandsenkowagon
                              Ok, never done anything with mix and match housings before, only whole units.
                              If i have a T3 .63 exhaust turbine housing with internal wastegate such as this: https://www.cartel-aus.com/product/k...xr6t-f6-gt35r/ could one reasonably expect to be able to swap a .63 3071 core into it, such as this: https://www.pulsarturbo.com.au/produ...37219618554006
                                You need a 35R turbine to go in that housing, Pulsar do them as CHRAs too. Or a GT30 turbine housing to go with that CHRA.
                                I have an original cast compressor GT3582 which I will start my home tuning with on the rx7, intending to buy the Pulsar swap in rotating assembly/core which should give around 10% more power and slightly better response and then step up to their G42 compact.
