    Put a reverse pattern valvebody in it
      And that reverses park how?
        When rebuilding a motor do you get the machining done to suit the rebuild kit or get the rebuild kit to suit the machining?
          get the machining done then get the rebuild kit. you'll know what different bits you need after
          if they cockup or something you can recover then, whereas if you already have the kit you'll need to exchange/replace it
            Measure first, order kit, machine to kit.
              Fitted a 2nd hand air compressor to a TS Astra today which I am assured is good.
              I cant hear it click on and off when the button is pressed.
              Guy reckons wont until gassed
              True / False?
              2013 Opel Insignia OPC
              2013 Kia Rio
              2018 LDV T60
                True / False?
                most likely true, if you turn a compressor and it has no gas (and more importantly oil) in it it will fucked really fast. refrigerant systems have high and/or low pressure switches so the clutch won't engage if the pressure is too high (cause it will blow up) or too low (cause the gas/oil has leaked out)
                why were you trying to turn it on with no gas in it?
                  Just started the car check fan belt ok etc pushed ac button and thought id hear click
                  But if that's the case that explains it then
                  2013 Kia Rio
                  2018 LDV T60
                    Yep its true
                      Did you put oil in it?
                      If not, tell your auto elec to put some in.
                        true, they need to see pressure before the clutch activates.
                          sure your not hearing a relay 'click'?
                          as said, it shouldnt be the AC clutch. turn the key on (motor not running), turn the a/c on, then see if you can spin the compressor by hand
                            Her mate is refrigerator mechanic and can gas for her....hopefully oil to.
                            Cars a POS I just help out where i can for her as she has no money.
                            I have to fix a massive oil leak on it tommorow
                            2013 Kia Rio
                            2018 LDV T60
                              hurry up and make with the pics then
                                What do you call more than one Prius?
                                Priuses? Priux? Priii?
                                Same for a Yaris too....
                                Previously known as Lobster, Chuss's brother's anus, Chuss's brother, Lobsook, Lobstersock, Socks, Sockz, MissAmericaImportGirl, ClutchCLobster, Clock Lobster
                                CJM 4 Life yo!
