    Originally posted by F3ARED View Post
    Have you guys tried seeing if you can adjust the headrest angle? On some cars you can click/adjust the head rest forward as well as up/down.
    Even with KIA's headrest in the most rearward position my chin touches my chest.
      How wrong/frowned upon is this method of a rust repair?
      I was always under the impression it was a big no-no to cut and weld on a structural member or chassis rail of a monocoque body, or does this only apply when a section is cut and but-welded on?
      I'm no expert, but I would have thought that it would have been better to cut a whole section of the rail out, not just a piece of it.
        what cut? what weld?
        While i do agree [as in, who the fuck would know] ive been in two big shunts in old cars so genuinely curious to know how it stacks up as a repair method given that Geminis have a habit of rusting in the LHR rail
        I thought that was worse as youd have two continuous butt-joins?
        1978 Gemini Sedan - Powered by i change my mind every week - R.I.P
        1980 Gemini Sedan
        1987 Range Rover Vogue
        1996 TF Holden Rodeo
          Originally posted by peal View Post
          Probably a lot better than the rust it replaced?
            Any good regular car wash people in mid South East melboure (Ashwood) . Need to get the two cars washed once a month at home ideally.
              No. But I would have braced the rail to support it during the cut. I've seen this repair method used a lot on Mustang torque boxes. If anything the end reault is better than the orginal shitty welds.
              Head rests. I was always told (read out aloud from some engineering article) that the proper adjustment of a head rest is the middle of the head rest should be at your ear level. Does that mnake the Kia's headrests betterer?
                Jims do that shit.
                Dr Hoon
                  Makes no difference.
                    Originally posted by nastysven View Post
                    Jims do that shit.
                    Hoping for some one reliable, e.g. not going to turn it into a swirly mess.
                      Are quality silicon coolant hoses ok?
                      Need to replace every 80's spec hose in my AW11 and I can either piece together an OEM kit from a million different suppliers and at great cost or just order one of the Stoney Racing silicon versions:
                      http://shop.stoneyracing.com/toyota-...lant-hose-kit/
                      Given I'll be running the Toyota red coolant which is compatible this seems much easier. Black of course, anything else is retarded.
                        yep, ive got silicon hoes on my water to oil cooler and off my rad. IMO they work better than equivalent rubber as they dont expand with heat and rot as much, small down side is they can be prick to slide on.
                          Silicon coolant hoses are fine, they are a common OE upgrade for various Police package vehicles where they work perfectly fine.
                          Only issue is silicon hoses are easily damaged, the OEMs use a protective sleeve where the hose may be damaged.
                            Thanks. I figured that was the case but was instantly suspicious of something available in a such wide variety of colours!
                            12 coolant hoses in an AW11. My mechanic is going to have fun with that one...
                              can a leak from the intake pipe (as it enters intake manifold, from intercooler) cause boost spikes?
                              used to get boost spikes and then my intake pipe popped off, turns out it hadn't been fixed in place properly. wondering if it had been leaking when under load/full boost
                                Does anyone make a cheap knock off of the Lokar floor mount shifters?
