Impreza RS Engine Failure.
    Does anyone have advice on how to approach the original workshop? I mean he could go in screaming and swinging fists but I don't think that will get him too far.
    HSV Caprice 5000i
      Re: Subaru
      Originally posted by 4G63JETT
      Last year I worked for 1 month doing Work experience at Subaru/Ford. We never really did have problems with the WRXs. they used to just come in for a regular service normally. The only bad WRX was a STi that came in with a Blown motor!!! And he got it replaced under warrenty. The WHOLE engine. I remember it clearly cos I had to help pull the bloody gearbox off it. I also have a STi piston which they gave me after they sent it off for inspection.
      Thats the one I'm talking about dude....was it Total Subaru??
        Get an independant expert to write a report on why the motor blew and then he can approach the orig workshop armed with a pretty strong backup as to why they shd fix it.
        Otherwise is will be his word against theirs and I'm sure they have loads of experience wriggling their way out of this type of situation.
          What ever happenned to people taking responsibility for their actions? Trying to get any dealer to fix it under warranty is the wrong thing to do. Even if you can get away with it, it's not right.
          By all means he should try to get it fixed by the workshop that did the (dodgy) mods. If he can't, then he should take it on the chin.
            "Oil can go missing on a Subaru easy! I put just over 4L in mine a week ago."
            crikey and people have the hide to say that an LS1 uses oil.. my ute used just under 1L in 10K, 3.5K of that towing a car on trailer...
              How long ago did you check your oil?? Are you saying you went through 4L in a week????? Or you had to top up 4L since you last checked the oil, either way that's HEAPS of consumption...With no major external leaks??
              Geez, I don't think you have any rings in your block....
              How long has that been happening, or only just recently?
              If the consumption is really that bad, I'd say the news will be too
              Pete
                I don't think the intake could have caused it even though it was dodgy.. The oil going out the crank breather goes through the engine and gets burnt anyway if it's connected up properly, so venting it wouldn't accelerate oil loss.
                as short as possible
                  My WRX burned 500ml of oil in the run in period, but its apparently normal for a new engine to burn a bit..
                  After I did the oil change, not one drop of my precious Mobil 1 5W-40 has gone missing, in almost 10 thousand km :D
                  *Edit* This is BALISTC by the way, not Mandee :p
                    The most horrible memorys at subaru are when they take freshly run in WRXs put this cleaner shit in the injection system, take em out the back and rev the absolute **** outta them.
                    That would be the upper head cleaner, smokey, but works well
                    Cheers
                    Jim
                    ride with me
                      Originally posted by nicemudflaps
                      Take it completely back to standard and take it to a different subaru dealership and act dumb......(for most people on this forum that aint much of a stretch) (jokin )
                      The shop that fitted the air filter is not gonna fix it for you so i reckon Subaru is your best bet.
                      If they ask you if you have modified the car in any way just deny deny deny..
                      But to a first year apprentice, they may not notice that the car has been modified, but to a senior mechanic, it would be pretty easy. Just looking at screws or bolts would be one giveaway.
                        you could say that it was the owners fault for not checking the oil level on a regular basis.
                        it seems as if the crankcase (devoid of any breathing apparatus) built up pressure and spewed it past a lot of the seals.
                        jon
                        flygti was stoped n G'ed up to do a a burn out,n as we all no it doesnt take much to get him g'ed, so he did the burnout but who could blame him he had earned it with the effort he put in to be in the cruise and help it go ahead safely
                        taken from www.hot4s.com.au
                        http://www.flickr.com/photos/jonisse...scientologist/
                          Stupid people are definately breeding.
                          Nice call Tony.
                          I hear we're going to Ape Island to capture a giant ape.
                          Yeah.
                          I wish we were going to Candy Apple Island!
                          Why? What's there?
                          Apes... but they are nicer.
                            Pete
                            I think I know what it is, I don't think it is bad however. It has not used any oil this week at all.
                            S
                            Have you heard??
                              DrNick,
                              A common problem is leakage around the tappet covers. If it happens on the passenger side the oil can get burnt off by the exhaust and be hard to find apart from a little misting near the gastket.
                              Happy Christmas
                                Originally posted by coyote
                                DrNick,
                                I think you are right on the money there. It is not dropping any oil at all, but you can smell it burning for sure. I know what else it is too however.
                                Thanks for the tip also!
                                Sean
                                Have you heard??
