places in brisbane that WILL roll guards?
This topic is closed.
    Did someone say superlows and 17's!!??
      It's not a lancer is it?
        I think it's a Soarer. Have you thought about purchasing a Lancer?
          its a gz10 soarer.. they are king spring LOWS .. for an ma61 supra.. my car uses same suspension..
          whats wrong with 17's? still has 45's on them
          Old School JZZ10 Soarer(85 soarer with 1jz conversion)
          R154 5 Speed manual
          600x300x76 Intercooler
          Ma61 Manual LSD...
          17 Inch Speedy Sirocco II's
          4x 234/45 rz17 Dunlop FM901's
          King Spring Lows
          Pedders Shocks
          All urethane bushes
            They're too small.
              Originally posted by Cookiemonster
              They're too small.
              Damn right.
              He needs to visit our mates at Tempe Tyres for some 20" rims.
              And then dump it on its arse.
              T.
                lol.. beleive me it does.. he set the right ammount for negative camber ... only 17 inch wheels with dunlop fm901's on it.. lowered about 1.5 inch...
                Lowered 1.5", and the negative camber is now "right". Well that's that problem sorted out.
                So the guards are your new bump stops then?
                -pete
                  lol.. yes they are.. till monday
                  the negative camber has been dialed in so it doesent rub on the rear guards until i get them rolled
                  R154 5 Speed manual
                  Ma61 Manual LSD...
                  King Spring Lows
                  Pedders Shocks
                  All urethane bushes
                    If only I'd known earlier,
                    wouldn't have shelled out big $$ for those coilovers!
                      Ahhh so when lowering a car you should dial in as much neg camber as possible to avoid rubbing. If that fails take to the car with a baseball bat. Have I got it right? and in some cases you can pay someone else to use their baseball bat?
                      I'm sooooo getting those neon superlow coilovers tomorrow. Can't wait. Would a rolling pin suffice?
                      -pete
                        why not swap your soarer for a magna. and put some 17"s with superlows on it
                        have you considered what rolling your guards will do to your oberfloggens?
                          come on pete
                          every man and his dog knows, the stiffer the better!
                          yes a rolling pin will suffice.
                          i'm testing a new one theory at the moment but I have a feeling the brighter the better
                            get over it guys.. the mass neg camber is only there for the next week or so until i get the guards rolled.. OTHERWISE id rip the sidewall to shreds on tyres worth 260ish each
                            can you all stop being such wankers?.. heh
                            when my guards are rolled.. im taking it back.. getting the camber fixed up and it shouldnt scrape.. and if u dont beleive it handles well.. come drive it :-P
                            R154 5 Speed manual
                            Ma61 Manual LSD...
                            King Spring Lows
                            Pedders Shocks
                            All urethane bushes
                              Originally posted by dazsta
                              somehow I doubt very much that your car handles great.
                              maybe its just me.
                              Have you driven it?
                              state street drift champion 2003
                              Formerly known as bassaholic55
                                Contrary to popular belief, lowering a car dramatically does not always affect handling negatively.
                                There's a lot to it including spring type/rate, shock type/rate, bushes used, factory suspension geometry, and wheel alignment settings.
                                That said.. if you're got stock shocks with lowered springs then you deserve all the tyre and guard damage you can cause in a weekend!
                                Originally posted by 350stato
                                100% agree with Shifty
