Water pump impeller clearance
    Hi All,
    I am working on a 1973 Saab 96 V4 at the moment and I have a question about water pump clearances.
    How much space should there be between the impeller and the rear housing on a water pump? I have had to build up the rear housing with epoxy as it was quite badly pitted (I suspect from cavitation rather than corrosion).
    At the moment I have impeller contact with no gasket, but should have about 1mm of clearance once both the gaskets are in place.
    Is that about right?
    Thanks,.
    Gasket clearance is a good start.
      That is about what I ended up with. Spins freely without hitting, seems to pump.
