VX airbag delete
    VX airbag delete
    I have a VX Commode that I've fitted VT SS seats to, & I need to know the ohm resistance of the side airbag resistor to defeat the airbag light etc.
    If you are inclined to get all butt-hurt over the illegality of this, please don't respond, as I'm not interested.
    If you've done this mod successfully, please add your knowledge...
    Thanks IA...
    Remove the bulb?
      Nope, won't work for rwc...
        Splice it into the ABS light...
        Originally posted by brewdles
          From memory the air bags are 2.2 - 2.8ohm, otherwise should be able to turn them off with a tech 2 or similar.
            The VE is 3.3 ohms, not sure of the VX
              Buy a couple 2.2, 2.8, and 3.3ohm (2W or higher) and swap them in until it works. Very cheap process of elimination.
                Many thanks to all...
                  Most decent scan tools can reprogram to the number of bags fitted
                    dunno ig holden did the same, but on Falcons there models that didn't get airbags, came with plug in resistors - maybe you can score some from a wrecker
                    GT-P
                    Bandsenkowagon
