Jack stand safety recalls
    SD Jack stand safety recalls
    Hi gents,
    There was some discussion on the PF discord about jack stands and product recalls, and I thought it was worth throwing a thread up here given the likelihood of seeing the official recall notice about those stands you bought years ago is probably slim to none.
    Main page, product recalls are listed here: Product Safety Australia - Vehicle Support Stands
    Of immediate concern for Autopro/Autobarn regulars:
    Automotive Brands Group Pty Ltd t/as Autopro and Autobarn - Extreme Garage Ratchet Jack Stand Range - 2000kg, 3000kg, 4000kg
    What are the defects?
    The product does not meet the requirements of the mandatory standard 'Consumer Protection Notice No. 12 of 2008, Consumer Product Safety Standard for Vehicle Support Stands'.
    Some products in this range may have a faulty latch that is either loose or has not been cast correctly.
    What are the hazards?
    The faulty latch can cause the ratchet jack stand to fall on to a person, resulting in serious injury or death.
    Recall Advertisement
    Repco:
    Repco 6 Ton sold between 8 Nov 2013 and 16 Feb 2018 Product Number RASTD6
    https://www.productsafety.gov.au/rec...support-stands
    The main column may fracture, rather than bend, if a load is dropped on its outer most edge.
    If the column fractures the load may fall, causing serious injury or death.
      My Aldi stands from 2 years ago look identical, how do I check ?
        'Digitel' aka ozstock.com.au 3 ton sold July/Sep 2017:
        https://www.productsafety.gov.au/rec...ton-jack-stand
        The product does not meet the requirements of the mandatory standard 'Consumer Protection Notice No. 12 of 2008, Consumer Product Safety Standard for Vehicle Support Stands'. The product may buckle during use.
        If the product buckles during use it may pos​e a crushing hazard, resulting in serious injury or death to the user.
          That's the worry - most of these things look (or are) the same. I would contact the recalls agency and hope you can get some sense as to how they check the same product being sold by multiple vendors: https://www.productsafety.gov.au/con...ake-an-enquiry
          Judging by the way the dates those recall notices are clustered together I wonder if they periodically test all available stands on the market(?)
            Its pretty crazy how often these things have a recall.
              A recall on a dodgy latch is pretty scary. Its one of the only things stopping you from having your face reconstructed by your sump. A mildly unpleasant thought.
                Farout that's a bit concerning. I have three pairs of these. Two std and four truck ones. I think they came from auto one but they look identical.
                Originally posted by Einstein
                  This is why PF is so fucking awesome.
                  Thanks andy_wk !
                  *edit*
                  Fuck Me, they're everywhere!
                  From an email that arrived in my inbox AFTER Andy posted this warning: Harbor Freight "Pittsburgh" branded, too:
                  https://images.harborfreight.com/hft...1196_61197.pdf
                    Good job andy_wk.
                    I bought a similar set to these that were faultily made - occurred to me that there was zero quality control of the end product as they couldn't lock at all. Scary stuff.
                      We stopped using the ratchet style stands on site a few years back based on this --> https://www.dmp.wa.gov.au/Documents/...MSB_SB_142.pdf
                      I still have a 3t and a 4t set at home, but when I use them I don't have them extended. The pin locking style ones are all that we use on site, and all I use at home if I actually need to get under something.
                      Emo 6 - Track
                      '74 Mazda 808 - Daily/Resto project [SOLD]
                      2010 Swift Sport of boredom
                        If I have to replace my Stanfred pin types (20 odd years old now) I’d be a bit stressed because it’s like every brand of stand gets recalled and the only answer is another stand that’ll be recalled a couple of years later.
                          My axle stands have a screw adjustment sorta like the chassis pads on a hoist with a giant wing nut thingy. Infinite adjustability is really handy and you can wind them up or down a bit while under load. I know they are more than 30 years old and still going strong. I don't know why I never see this type of stand as I think they are a great idea. I sometimes think about getting rid of them and buying new ones but then common sense kicks.
                            *high-fives* for Stan & Fred!
                            I've got two pair, bought a few years apart; they're different shades of blue, and the older ones have a wider doohickey that the frame-rail sits in.
                            They seem sturdy enough, and it's not like there's much to fail.
                              I have the pin-type ones as well.
                              Always preferred them to the ratchet style.
                              Originally posted by brewdles
