How long should Jack stands, ramps and car jacks last?
    So I pulled the car ramps out the other day. They are in mint condition and show no signs of wear or damage. But I realised they are over 20 years old, for WA peeps, they where bought at Marlows! My smaller car stands are also in mint condition and about the same age.
    So my question is, if in good nick, how long should they last? When should someone consider buying a new set (knowing my luck will be recalled twice due to crap welds)
    Also how long should a trolley jack last? Mine gets an oil change every few years and a quick inspection of the seals. If it looks good then I keep using it or get it serviced. But no one has ever said anything about them, getting checked or having a shelf life.
    I think that as long as there is no damage/fatigue to the metal, and no signs of rust of corrosion etc, then they should be fine for many years.
    If theyre 20 years old then theyre likely not made to the same bottom line as the regularly recalled ones that are sold today.
    Were they cheapies when you bought them, or higher spec?
      Long enough to get out from under when you hear a creak
        Sydney harbour bridge has been there 90 years
          I have 40 year old car ramps, still strong as fuck. A 2.4 ton Audi Q7 doesn't even make them flinch.
            Hoges never maintained mizone’s ramps, though!
            Mine seem fine & are probably 25 years old, although they’re useless for the Volvo ... front & rear ends are all empty-air crumple-zone, which pulls the wheelbase in from the front & rear bumpers a fair bit, so ramp-angle is way more For The Suck than the Commode.
              If possible, no matter the age, you should always try to have 2 forms of support/backup when you are under the car anyway.
                In my non expert opinion a jack is less of an issue since you're never under a vehicle when on a jack only (right?). If it lifts it to get a stand under, it's fine. Stands on the other hand, prefer to keep a jack there wherever possible as a back up. If two sets of jack stands fit in different places then do that too.
                So if they look fine and aren't riddled with rust I'm good to go. My older stands (3 sets) do have a bit of "surface rust" but I'm still confident with them. They are the backup at best though.
                All a case of risk management.
                  Thanks for the input lads
                  Middle of the road. I paid more for them back then that a new higher weight rating one would cost now.
                  I think that goes without saying, I shove a newish 6 tonne axle stand under everything so that if it does give way I'll die slowly and it will hurt the whole time I'm dying.
                    find something else to worry about dude.
                      i use jack stands that are about 40 years old, no apparent cracks or damage so i keep using them.
                      oh, and i still haven't been crushed by my quickjacks
                        I’ve seen some people’s rusty ramps and stands that live outside 24x7, I’ve seen newish stands be bent by a car being toppled off them, beaten “straight” and put back to use.
                        Ain’t getting under those options at all.
                        I trust my 25+ year old ones because they aren’t treated like the above. Then again I’m a wuss.
                          As I typed the original post I thought, Damn, I hope the drummer from Steal Panther would chime in with a good joke. I am disappoint.
                            Intended life was 100 years though. They had to abandon the intended additional deck idea back in the late 90s early 00s(?), because structure was no longer up to design strength.
                            Do have old pressed metal base, pin in hole, jack stands that are probably 60s vintage, that still seem ok, but no chinesium steel or welding in those days.
                              I have a pair of ramps that I got given (used - with a dent in one of them) so long ago I can't remember.
                              They live outside and still work fine. Look like the paint was Marlows blue.
