Keep turbos or go cam?
    Hey fellas,
    I've got a backyard twin turbo ve SSV. Has done pretty well for ten years or so, love the noise and the torque but has had issues.
    The two major issues now are play in the turbos necessitating a rebuild/new turbos and the constant heat they produce. That can be mitigated somewhat but if I'm honest, in not so inclined with the upkeep as I used to be.
    I'm in a rare position where it's in the North and I can get it shipped somewhere en route back to Tas, likely Melbourne (would love to get it to Al or CHE but Melbs better), and can get some things done (move scavenger pump, change pickup, get some venting sorted) or pull it all off and whack a cam in to improve the general reliability and not slowly cook everything in the engine bay.
    Thoughts?
    The right "turbo" cam with nice tight Lobe separation and lift combined with the spooly bois would go good. You need to take the turbo's off to get to the cam chest so give them a birthday and enjoy earlier and longer torque curve.
    The head management could be solved while the manifold is all off.
      I did think about that when I last had the motor out Brasher and it would have been rad but trying to not constantly spend money on maintenance, have something that's not always got something that needs money spent and still enjoying it are the goal.
      Have other priorities now like trying to get a block so cutting back on car spends for a while.
        Cliffs can it be done and kept running cost effectively or would cams be more cost effective if I'm keeping this long term.
          Unless the turbo install is truly shit, I imagine just fitting the classic old cam+zorst will give Much Disappointment compared to the turbo torque.
          However my proposed alternative is going to be a lot more exxy - one of the 18 million blower kits available.
            What's causing the heat? Are the housings the right size and not getting choked creating a lot of heat? What about ceramic coating the exhaust housing and manifolds? You'll find it really difficult to go backwards imo. I wouldn't think properly sized turbo's with a reasonable boost level would create too much excess heat? As it's a backyard kit maybe the matching of components is the issue. Just stop at Skidfactory on your way home and let Al fix it!
              LOL
              If you take the turbo's off, you'll wonder where all the powers went.
              A cam ain't gonna cut it.
              If you leave them on you will continue to cook everything.
              You can't have your cake and eat it, or your block and turbos, sensibly, convert it back to n.a. keep the turbos &etc. buy block and refit when circumstances allow, probably quite some years down the track.
                fuck the twins off, go single. everyone wins.
                  Yep cams and blower. Old school!
                  Or have the turbo's rebuilt and ceramic coat everything and heat wrap.
                    Ceramic coat and the alloy or inconel heat shielding all over. If ignition timing at cruise is where it should be and you have coated/wrapped/shielded stuff it shouldn't be a massive issue.
                      Ceramic coat does Jack shit. People don't realise how hot turbo engine bays can get.
                      Mild cam will sound nice and still move
                      Originally posted by 50RTD
                        This'd be like dumping a dirty bitch that deepthroats, does ass-to-mouth & sits on your face for fun, for a frump that will only do missionary with the lights off & might suck your dick on your birthday, but only for a minute...
                        Originally posted by nutttr
                          This.
                          Very sigworthy also.
                            I don't see cams that cheap an option as you already have the turbos on. Unless you can get some good coin for the kit.
                            By the time you buy headers, decent otr intake, cams, valve spings, gaskets, labour it starts to add up.
                            Surley it would be a LOT cheaper to go bigger on the ex housings, heat wrap everything, buy some of that mouldable heat shield stuff and run a few psi less and call it a day. The result will obviously be much better also as you wont be going backwards
                            Sent from my SM-N960N using Tapatalk
                              Wrap down pipes with 1” ceramic fiber and get blankets over the turbos.
