Home mill and lathe options? Halfco the go?
    It would be fairly easy to rig up a full width baseplate on the swivel bandsaw. Slightly harder on the base 6x4 but not impossible. It’s one thing I am planning on doing.
      Originally posted by [RX3] View Post
      https://www.machineryhouse.com.au/B062V
      Non dual mitre might be a good option for you too as its a bit cheaper, albeit on sale.
      That looks pretty good, I was hoping to seal the floor before buying too much stuff but I think I might grab one.
        Now that I think about it I am not too sure how that would go doing lobster cuts less than 10 degrees as there seem to be intents which might cause the blade to cut into he metal support if cutting at angles between zero and 10 degrees. Maybe keep that in mind or ask about it when you look at em.
        Click image for larger version  Name:	image_128663.jpg Views:	17 Size:	136.6 KB ID:	7296913
        EDIT ^^^ Thats probably 15 degrees and not 10.
        As annoying as I found mine with some limits, it was really helpful when making exhaust and cutting 90 tube in half for a dump pipe ect.
          Originally posted by Dimi View Post
          I think you've got that back to front mate.
          You need minimum teeth engagement for the TPI count
          1.2mm tube with 10TPI blade is a no bueno
          Using this
          https://www.machineryhouse.com.au/B006
          With a pretty coarse blade, not sure of the TPI but its not fine, its a fucking machine for making exhausts.
          Not a hope in hell I would go back to using an abrasive chop saw
            Just put a sacrificial block under whatever you're cutting. It won't be a problem.
            Originally posted by Marlin
              Sacrificial block will disable the auto stop switch though.
                I'm guessing you could shim the switch striker/rest as well.
                  It depends on how it is done. On mine there is an adjustment screw, but it would get tiresome adjusting it for the different depths. I guess one could rig up some quick change system for the striker for one with an extra X length for the sacrificial surface.
                    Im a butcher, I just let it cut the bed on mine.
                    GURU Motorsport ENGINEERING PTY LTD
                      Oh, the horror!
                        Oh, the horror!
                        Autostop is perhaps the best bit of the bandsaw, set and forget and come back later when its done. No need to babysit it while it is cutting.
                          There was a bit of this on the pit one, didn't seem to cause any problems
