Water in Petrol - longterm effects?
    no it's steel just checked my sister in laws,should have known i just changed the rear shocks on her car and smacked my head on the bloody tow bar.
    Yes i know,i am one eyed holden :worship:
    And this forum's token complete and utter fucktard.
      my sister in law had a similar problem filling up at an independant servo and i put a few cups of metho in it ,can't hurt.
        ED onward falcons are plastic
        Marketing says its for safety
        Everyone else says its for cost cutting.
        Originally posted by paul05
          Dunno if it's only the BAs, but they have a sump plug in the tank so you can drain the petrol easily......would have come in handy for me.....funnily enough, the two other guys were in Falcons.....
          Edit: will check if the workshop chucked some metho in, he mentioned it might need it, but dunno if he actually did it or not before we picked it up.
          Nathan
          Speed Shots Photography
            metal tans deform then rupture. plastic tanks deform a lot more before they will rupture.
            and they're cheaper.
              Which explodes first in event of a fire? Or no difference when it's that hot?
              Nathan
                depends on where the fire is! But the fuel in either tank will expand and force out the filler or breather and ignite before even the plastic tank melts.
                  Originally posted by Nafe
                  Thanks Secoh,
                  Tank was removed and drained within about 4 hours of it happening. Lines got blown clean and flushed too. Car seems to be okay, but will take it for a longish drive and make doubly sure.
                  I think everything that you got done it will be fine.
                    OKay, so the car seems to be running fine now..... except......
                    When starting stone cold (e.g. overnight, or left in the carpark all day), the car doesn't seem to fire up immediately. The engine will crank for 2-3 seconds before maybe firing up. Second go, it starts up perfectly. When its only been left for an hour or two, it also seems to start fine. Drivnig is no problem, no hesitation, no spluttering, all running smoothly. Idles fine too.
                    ECU prob? It's only occurred since the fuel prob, but we also changed the battery, although I don't think that would reset the ECU at all in the Commodore?
                    Tried turning on the ignition and leaving it a few secos before firing. Still cranks and cranks before maybe catching. Almost as if there's no fuel, or no spark. I suspect the former though.
                    Any ideas?
                    Nathan
                      XD onwards have a plastic tank, or was it XE? I'm not 100% sure, although I know for a fact that my XF has one
                      Gab
                      `85 XF Falcon, 4.1 EFI 5 speed, 12 slotters, lowered, Ghia interior, Sports Steering wheel. Coming soon: LSD & stereo
                        Nafe care to mention the location of the Shell (PM perhaps?)?
                          You have PM
                          Nathan
                            nafe check your spark plugs for the cold starting problems either change them or give them a clean, simple to do
                              New sparkies went in when the lines were cleaned etc. The car runs perfectly in all areas, except for that initial cold start. Might have to pull the sparks and make sure they are the same temp range etc as the old ones....?
                              Nathan
                                Originally posted by fdrx7
                                Moral of the story: Only fill up your car at a servo with new tanks. Servo operators seem to wait for a drama like this before bothering to fix the tanks. eg in Brisbane there was Shell at Indro and Ampol/Caltex at Windsor that went through this.
                                Actually, the moral of the story is... don't fill up at Shell full stop unless it's an emergency.
