Cleaning products for throttle body???
    Hey all.
    My old Bimmer with it's "advanced" vacuum controlled idle/ignition setup needs a big clean.
    What products are good at removing carbon/gunk buildup?
    I'm thinking just some degreaser and a tooth brush but feel free to suggest anything else.
    carby cleaner is pretty good for cleaning up gunk in places like that..
    everytime you masterbate god kills a skyline.
      but I don't have a "carby"..... Noob!!!!!!!!!
      :p
      Good idea.
        Subaru top end cleaner - about $16 a can.
        Now without LS1........again!
          CRC sell a Throttle Body Cleaner, which looks, smells and acts much like Carby Cleaner.
          In fact I think the packaging says ("can also be used on carbies").
            bodgy liked his oven cleaner iirc
            Thank You,
            Management.
            8 cylinders, 5 carby's, 6 wheels.
              carbie cleaner is good because it is designed so it doesnt leave an oily residue. It really doesnt matter much mate, just soak the thing and attack it with a tooth brush if you cant get it all clean.
                Wire brush & Dettol.
                  are you talking shit Bill or are you saying I should keep the dettol on hand for the comming injurys?
                    When in doubt, assume I'm talking shit.
                      Throttle body cleaner is not as harsh as carby cleaner. Nulon make a good one too. Apparently carby cleaner can melt bits of the injectors - not nice.
                        The plastic maybe if you soak it for long enough.
                        The throttle body is quite a long distance away from them though, i imagine he is going to unbolt it aswell.
                          you imagine right the throttle body won't be in the car when I clean it. I'm not a gynecologist.
                          Although I could be, for the right woman :D
                            yay.
                            Well it's all clean now and the car's idle is smoother however I also discovered some other problems...
                            need some new wheel bearings for the front.
                            need to get the radiator cleaned/replaced and fit a new thermostat as I currently don't have one.... slack previous owners... grrr.
                              Damn, should have left the TB dirty then hey :p :D
                              Are the conventional wheel bearings or sealed press in exxy ones? I dunno whats worse - forking out for sealed ones & paying someone with a press to fit them or packing the conventional ones by hand.
                              XLII - 101010 - 2A
