Originally posted by 200sxtc
Emergency braking is what you do in a "panic stop", in scenarios described earlier (kid/dog/goat/rock runs out on road, goblins appear from the earth, etc). In this instance, it's a single application, single instance.
If you or anyone has the presence of mind to be gearing down while applying the maximum braking effort available, good luck to them. I (and almost, if not all of the driving public, I would suggest) is not sufficiently skilled to be gearing down in a panic situation.
That ABS knocks so much off Joe Publics stopping distance shows that they don't know how to effectively use all braking capacity available to them, and asking them to gear down while using cadence is probably more than they can stand...
/gross generalisation rant...
, as well as save the brakes a bit.
