braided hose
    owwww, that doesnt make me happy. I wont deal well with it stinking of fuel. Im going to have to buy this teflon stuff...fuggin.
      Originally posted by edo
      Fark, thats no good. Original capri tank is up under the parcel shelf, but Im not using that.
      Is this teflon cored stuff just slightly more expensive than solid gold fuel hose?
      Ive seen all the V8supercars run their lines inside, & as I'll be running brake lines inside too I was just not putting anything underneath the car.
      i was quoted $88.72 per metre for -10 and $60.10 per metre for -6 braided line thats teflon coated.. so more then double the cost of normal
      Originally posted by Lobster
        ok, Thats not so bad...not so good, but I wont need a lot.
          i havnt really noticed it, just running a rubber hose with a surge tank in the back (hatch) admittedly its not running to the front of the cabin but maybe im just used to it by now hahaha
            nismogemini,
            its not teflon coated rather it has a nylon/teflon core covered in braid to protect it....
            im sure enzed / pirtek can assist with teflon line...speedflow do make that product but not many places stock it..
            the other thing to know about teflon hose is that they prefer a crimped fitting on the end...hose clamps don't really work, and regular speedflow / aeroquip / earls braid fittings won't fit as the ID and OD of the hose is different to rubber cored stuff....
            bundy tube will get my vote guy, and just use flares on each end to go to flexi bendy hose
              is bundy tube just the steel tubing like in stock setups? That's all I've ever used in the rally cars. Just make sure there's no joins in the cabin.
                The teflon stuff uses compression fittings (ie a brass olive crimps onto the teflon tube).
                Earls do a range of this stuff but i'm not sure how big they make it, the stuff I used was only -4.
                EH Holden RB20 Build
                  browny is on the money, i have only seen 're-useable' fittings for teflon up to -4...
                    Oh, well fark it then, I'll put the solid line in & just have the shiny stuff in the boot & engine bay.
                      Isn't running stainless tube cheaper than braided line?
                      I was gooing to remake my PS and auto tranny cooling lines out of stainless tube and then take it to pertek to get the ends put on.
                      Is there anything wrong with this?
                      edo,
                      if your really keen couldn't you just polish the lines inside the car to get that suedo shiny expensive stuff look?
                        My boxed surge tank in the boot does smell a bit on hot days and it's partitioned off from me by the rear seat and is inside it's box as well although the box is far from air tight. If the lines were in the cabin i'm sure it'd be worse. I'm just using normal fuel line with a big bulky red fuel line (dunno what it is but it sure has thick walls) running to my main pump.
                        If looks could kill you'd have eyes like cyanide...
                        New Daily and Drift: S13 Silvia SR20DET
                        Daily and Drift: S12 Nissan Gazelle SGL SR20DET *sold*
                        Project Drift: 910 Bluebird CA18DET *sold*
                          I could but its probably not my cup of tea.
                          Im just as happy having it all painted when the cage goes in.
                            KDog
                            If its a DIY job with any sort of complexity, be prepared to budget for about twice as much tube and triple the time because of farkups. Plus AFAIK stainless is more of a biatch to bend so add some more to both of the above.
                            I went through something like 20m of tubing to get the hardlines nice and neat under my car because I ended up tossing my first attempt. Wasn't impressed when I got it all perfect on the second go then had a brain fade and drilled through the floor and managed to hit both, luckily it was repairable.
                              Originally posted by browny
                              Wasn't impressed when I got it all perfect on the second go then had a brain fade and drilled through the floor and managed to hit both, luckily it was repairable.[/img]
                              :rotflol: I thought it was only me that did things like that!
                                Why do you think I want to run absolutely everything on the topside of the floor?
