Electrical connectors
    Originally posted by tortfeaser
    Deutsch AS series. http://www.compsystems.com.au/autosport.htm
    Bling. That is all.
    now your talking,
    i use them on everything, expansive to setup with the correct crimpers etc but once you are setup you will never go back!
      Just for us dreamers out here, what sort of $ are we talking for the crimpers?
      EH Holden RB20 Build
        they are not too bad, around $160 from memory, that is the ones to crimp the solid pins, jaycar sell a great set of crimping the normal type pins but they will cost around $85
        Dale
          That seems very reasonable. Cheap enough to be affordable to DIYers. I was expecting $500+.
            are they normal hand crimpers or ratchet style?
            got any pics?
              There's a downloadable PDF from the web site that shows the Deutsch crimper.
              I called Comp Systems re connector pricing. 6 way ~ $15. Darn good I reckon.
                mine look different to the ones on the site, same basic design tho
                attached is the pic,
                the total cost of a 8 pin connector with the housings and pins works out at about $30 from memroy
                  Thats for the solid pins yeah?
                  Whats better, solid pins or stamped and formed?
                  Do the solid pins crimp onto the insulation to prevent the wires from taking any mechanical load?
                    i use the solid pins, i hate the other type, too much fiddling around when crimping etc
                    the wire is stripped back 5mm and then inserted into the pins, only the core of the wire is crimped,
