Originally posted by Supercrown
Greetings guys,
I entered the crown in my first full dyno comp over the weekend here in Adelaide at the ExtremeHorsepowerSuperShow (yes-it's actually called that..)-and had an absolute ball-here's the rundown.
The main comp was on Towler Performances Dyno Dynamics in full Shootout mode. Every one was complaining it was reading low-but we were all on a level playing field-so who cares!
1st run was with BFG drag radials. They overheated, blistered and virtually liquified causing wheelspin and limiting the car to 333rwkw.
2nd run I put on the trusty Simex Light Truck tyres, and I also had them strap it down HARD with only 16psi in the tyres, and then jam them up to 60psi after. That fixed the problem and it went 392rwkw.
3rd run I was trying to knock off a yellow 2JZ supra (1000+hp built motor) that had pulled 412rwkw. (bloody manuals!
) I wound the boost up to about 22 psi and went 400rwkw, and then went to 23-24 (not sure-I didn't want to look), but it leaned out and only made 1 more-401rwkw. (well derr-the 044 pump is rated to 600hp...good work einstein) Had I been able to fatten the fuel up it it should have gone better-but meh, it was awesome fun having a go anyway, and the car didn't miss a beat for the whole weekend.
That put it in 2nd outright behind Ben's Supra I84RE (top bloke), and in front of a big block HQ in 3rd.
I then took it over to the 800hp Dynapack dyno in the main pavillion as I've always wanted to use one. I pulled the boost back to around 19-20psi, and he did a quick test ramp to 4400 rpm (it makes max at around 5100). Result-442kw(593hp)!! He then tried a full power run, but as soon as the boost hit, the display screen flashed red with "TORQUE CAPACITY EXCEEDED, ABORT RUN IMMEDIATELY, DYNO WILL SHUT DOWN IN 15 SECONDS"!! They then re-booted the system, and he tried to do a power pull from about 4000 rpm (after peak torque), however it did the same thing again almost instantly. The dyno is rated to 3300nm at the hub.........He wants me to go up to his workshop when he has the software upgrade to allow it to handle 4400nm and 1100hp. The guys said that last week they had the Dynapack at Tenix to dyno a tank, and that didn't top it out......
Supercrown 1, Dynapack nil. :knock:
I had an awesome weekend anyway.
Sean.=-)
(I'll put some pics up later today)
) I wound the boost up to about 22 psi and went 400rwkw, and then went to 23-24 (not sure-I didn't want to look), but it leaned out and only made 1 more-401rwkw. (well derr-the 044 pump is rated to 600hp...good work einstein) Had I been able to fatten the fuel up it it should have gone better-but meh, it was awesome fun having a go anyway, and the car didn't miss a beat for the whole weekend.That put it in 2nd outright behind Ben's Supra I84RE (top bloke), and in front of a big block HQ in 3rd.
Sean.=-)
